jankop wrote:I'm against it. If not rise significantly memory requirements of programs, so it is clearly beneficial. I even edited the first program for FP.
> =(600-600%70)/70
8
This does not work for negative numbers !
Explore... Chat... Share...
> =(600-600%70)/70
8
NodeMCU 0.9.5 build 20150123 powered by Lua 5.1.4
rl l | l | l b| r b b nn lnn b p lrlrlp n l b n | r b nn l l` nn l nr n b
l` p n r b n | b nn l` nn l nr n bl lp n r lb b n | l l b nn l` nn l
nr n ` r n ` MEM CHECK FAIL!!!
r
