function testserver()
local srv = net.createServer(net.TCP, 100)
srv:listen(80, function(conn)
conn:on("receive", function(conn, payload)
local isopen = false
conn:on("sent", function(conn)
if not isopen then
isopen = true
file.open("bigfile.html", "r")
local data = file.read()
if data then
conn:send(data)
file.close()
conn:close()
conn = nil
end)
conn:send("HTTP/1.1 200 OK\r\n")
conn:send("Content-type: text/html\r\n")
conn:send("Connection: close\r\n\r\n")
end)
end)
testserver()
@picstart: Here is a slightly modified function from ThomasW (viewtopic.php?f=19&t=702&start=30#p4467) which quickly delivers a big file:
Thank you this was very nice...I was overly concerned that this payload issue went unaddressed after 0.9.2....Code that worked with 0.9.2 now is working again.
The solution posted above works very well for lager files
Thank you
Has anyone found a way to upload a small jpg file via ex Lualoader 0.70?
Lualoader 0.70 works for textual files but that's about it.
picstart wrote:@picstart: Here is a slightly modified function from ThomasW (viewtopic.php?f=19&t=702&start=30#p4467) which quickly delivers a big file:
Thank you
Lua can't send jpeg files over tcp or any other protocol yet. You can upload with tftpd but you can't use
Lets get the party started and +1
[url=https://www.banggood.com/custlink/KvGGhGF4wG[/url]
I like ESP8266 and ESP8285 and ESP32
