By ohgary
#6209 Was working on my esp8266 with the lua code loaded and ran into an interesting issues. I am using rom NodeMcu 0.9.4 build 20141230 powered by Lua 5.1.4
The following program runs with no issues.
while 1 do
print("led on")
tmr.delay(2000000)
print("led off")
tmr.delay(2000000)
If I change the delay line tmr.delay(200000) the esp8266 seems to crash and restart.
Below is the esplorer push to chip and chip running along with the error.
> node.restart()
nil
while 1 do
print("led on")
>> tmr.delay(200000)
print("led off")
tmr.delay(200000)
>> end
led on
led off
led on
led off
led on
led off
led on
led off
led on
led off
led on
led off
nil
By Quindor
#7139 The hardware timer has a watchdog function which will reset the ESP after a certain amount of hanging or in this case delaying (which hangs everything).
You can try and issue a watchdog reset between the delays, but it's a patch stop at best. I think you can work around it with an alarm trigger loop. Take a look at my code, it should provide you with a solution!
http://www.esp8266.com/viewtopic.php?f=24&t=1021&p=5645#p5645
