By cal
#13119 Moin,
a simple lua TCP server application on ESP 01 using build 20150318 crashed for me with nil accesses
when called in a loop.
To debug that I
    checked out esp-opensdk/ 31ef9133b581788a9766245566da3154f84a9683
    checked out nodemcu-firmware/d8f2c2ba3455f7e132f46b41c97deb5df24c04ec (2015-03-29)
    enabled debug module and readline method
    module net: replaced lua_call with wrapper for lua_pcall + printing callback + line number in net.c
    found out that the problem was caused by what seems net_server_disconnected calling a nil callback
    found out after some time that there never was a callback installed but:
log output from 115200 Baud c_printf:
net_delete: cb clear: 3fff8520
net_server_disconnected: dis cb vanished: 3fff8520/ffffffff
The hex values are pointers of the nud-Structure.
c_printf("net_delete: cb clear: %08x\n", nud);
I interpret that as net_delete freeing the data structure and net_server_disconnect accessing the data structure
afterwards, finding garbage and interpreting that as callback.
Didn't find/look into the SDK docs of callbacks yet (anyone a hint where to look?) to see
whats documented about SDB callback orders.
I found it very useful to see the line number of cfile doing bogus lua_call and get stacktraces (surely not integrated well). I saw that debug.debug() does not work but that could be replaced with printing "not supported yet".
Other than that tracebacks worked well for me.
I didn't looked how much memory it did cost or how much performance.
I assume adding an image to the builds that includes debug module and provides tracebacks on PANIC would
improve bug reports alot.
Even if you find out that some callback was tries to be executed without ever being installed. ;-)
Keep on going,
Carsten
By cal
#13122 Here the TCP-Server code I wrote. Thanks to all the various donors providing examples in the forum!
Code: Select allport = 80
if srv ~= nil then srv:close() end
srv=net.createServer(net.TCP)
srv:listen(port,
    function(conn)
       local status,err = pcall(handleConn, conn)
       if not status then
           print ("handleCall failed:" .. err)
     end)
function handleConn(conn)
    local page = "OK"
    if conn == nil then
       print("conn vanished!!")
        conn:send(page)
        conn:on("sent", function(conn)
            conn:close()
            --print(debug.traceback("Stack trace"))
            collectgarbage("collect")
            local heap = node.heap()
            if (heap < 4000) then
                print("heap too low, delaying, " .. heap)
                tmr.delay(1000000)
        end)
