This script should get a string from my serial split it and then send it by mqtt one word at a time.
All is good until my client loses connection and needs to reconnect to broker. After it finishes reconnecting it somehow returns to the sendit function and starts trying to execute what's inside the publish (function(send)) callback. And only afterwards triggers the reconnected function from my timer alarm.
Note that this does not happen if it didn't publish something before the disconnect. My fix was adding the if message[i] otherwise it would break my script.
Is this normal? I mean wtf
m = mqtt.Client("NODEMCU", 120, "", "")
m:on("offline", function(disconnect)
print("Reconnecting to MQTT...")
print(node.heap())
tmr.alarm(1, 10000, 0, function()
m:connect("192.168.1.99", 1883, function(reconnected)
print("Reconnected to MQTT.")
tmr.stop(1)
end)
end)
end)
m:on("connect", function(connected)
print("Connected to MQTT.")
end)
m:connect("192.168.1.99", 1883, 0)
uart.on("data", "\r", function(data)
print("Received from RX: ", data)
dosend(data)
if data=="quit\r" then
print("Waiting for RX input...")
uart.on("data")
end, 0)
function sendit(message,i)
print("MQTT sending package : " ..message[i])
m:publish("/data/"..i,message[i],0,0, function(send)
-- PROBLEM HERE
if message[i] then
print("MQTT sent package : " ..message[i])
i=i+1
if message[i] then
sendit(message,i)
end)
function mysplit(inputstr, sep)
if sep == nil then
sep = "%s"
local t={} ; i=1
for str in string.gmatch(inputstr, "([^"..sep.."]+)") do
t[i] = str
i = i + 1
return t
function dosend(message)
v=mysplit(message)
i=1
while v[i] do
print("Got args : " ..v[i])
i=i+1
sendit(v,1)
