local api_host = 'api.thingspeak.com'
local api_path = '/update'
local get_template = 'GET '..api_path..'?api_key='..api_key
local function update_factory(getstring)
return function (s)
if debug then print('Connected!') end
if debug then print('Sending: '..getstring) end
s:send(getstring..'\r\n\r\n')
local function sendUpdate(getstring)
local s = net.createConnection(net.TCP, 1)
if debug then print("socket created...") end
s:connect(443,api_host)
if debug then print ("connect requested...") end
s:on("connection", update_factory(getstring) )
s:on("receive", function (s, r) if debug then print("Return from API: "..r) s:close() end end)
function M.update(data)
local getstring = get_template
for i,v in ipairs(data) do
if i < 9 then
if debug then print('Field '..i..':'..v) end
getstring = getstring.."&field"..i.."="..v
if debug then print('Preparing connection') end
endI set debug to true in the global scope, and It gets as far as "connect requested..." but never actually seems to connect. Not in a position where I can get a packet capture right now, any thoughts?
One thing I thought is maybe s falls out of scope and gets GC'd after sendUpdate ends?
