By paw1976
#15458 Hi.
Hello.
I have a problem with the following code that works only in
nodemcu_integer_0.9.6-dev_20150406 version.
I tried to use other
nodemcu-firmware_v20150213.6
nodemcu_float_0.9.6-dev_20150406
nodemcu_integer_0.9.5_20150318
and for me it does not work properly.
For example, "admin: public" should be coded as YWRtaW46cHVibGlj but it is YWRtaW46bHVibGlj.
I would like to use this in float version. Can You help?
This is the source
https://github.com/nodemcu/nodemcu-firm ... les/base64
Best Regards Paul
