often causes a
PANIC: unprotected error in call to Lua API (stdin:2: bad argument #1 to 'pairs' (table or rotable expected, got nil))
The solution I found is this:
https://github.com/nodemcu/nodemcu-firm ... /435/files
Explore... Chat... Share...
function(table): a callback function to receive ap table when scan is done
this function receive a table, the key is the ssid, value is other info in format: authmode,rssi,bssid,channel
In case of a scanning error the functions receives nil. Make sure to check for nil before accessing the parameter.
kriegste wrote:This callback is from one of the examples.
The PANIC crashes Nodemcu, causing a reset.
Sometimes it hangs after the restart.
