Transport Connection to: tcp://10.0.2.2:40948 failed: java.net.ProtocolException: Invalid CONNECT encodingIt appears that the MQTT client within nodemcu is not setting protocol correctly
Explore... Chat... Share...
Transport Connection to: tcp://10.0.2.2:40948 failed: java.net.ProtocolException: Invalid CONNECT encodingIt takes about 20-25 seconds for home assistant c[…]
