By GeekBoy
#30087 hi guy :D
i flashed the last firmware with ESP8266Flasher
and after that uploaded this lua code via luauploader and ESPlorer
Code: Select all--wifi.sta.setip({ip="192.168.1.10",netmask="255.255.252.0",gateway="192.168.1.1"})
wifi.setmode(wifi.SOFTAP);
--wifi.sta.config("SSID","pass")
wifi.ap.config({ssid="test",pwd="12345678"});
gpio2_state=1;
gpio0_state=1;
gpio.mode(3, gpio.OUTPUT,gpio.PULLUP)
gpio.mode(4, gpio.OUTPUT,gpio.PULLUP)
responseHeader = function(code, type)
     return "HTTP/1.1 " .. code .. "\r\nConnection: close\r\nServer: nunu-Luaweb\r\nContent-Type: " .. type .. "\r\n\r\n";
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
    conn:on("receive", function(client,request)
        client:send(responseHeader("200 OK","text/html"));
        local buf2 = "";
        local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
      --  print(request);
        if(method == nil)then
            _, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
        local _GET = {}
        if (vars ~= nil)then
            for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
                _GET[k] = v
        local _on,_off = "","";
        if(_GET.OFF == "1")then
            gpio.write(3, gpio.LOW);
        elseif(_GET.ON == "1")then
            gpio.write(3, gpio.HIGH);
        elseif(_GET.OFF == "2")then
            gpio.write(4, gpio.LOW);
        elseif(_GET.ON == "2")then
            gpio.write(4, gpio.HIGH);
        buf2 = "<html><body>";
        buf2 = buf2.."<p>GPIO 1<a href=\"?ON=1\"><button>ON</button></a>&nbsp;<a href=\"?OFF=1\"><button>OFF</button></a></p>";
        buf2 = buf2.."<p>GPIO 2<a href=\"?ON=2\"><button>ON</button></a>&nbsp;<a href=\"?OFF=2\"><button>OFF</button></a></p>";
        buf2 = buf2.."</center></body></html>";
        client:send(buf2);
        client:close();
        collectgarbage();
    end)
end)
its work like charm
but unfortunately after reconnect USB arduino (i used arduino instead USB to TTL board ) two GPIO 0,2 get high and ip address won't work
please help me engineers ;)
