By Oetsch
#30465 Hi
I´m just a beginner in programming lua and at the moment trying to setup a DHT11 sensor.
For that reason I tried to use actual modules from github provided with the actual firmware.
But when i upload or by an example script try to use the dht_lib.lua I got an error message:
stdin:1: ')' expected near ']'
Can anybody help to fix this problem?
Thank you very much!
Code: Select all-- ***************************************************************************
-- DHTxx(11,21,22) module for ESP8266 with nodeMCU
-- Written by Javier Yanez mod by Martin
-- but based on a script of Pigs Fly from ESP8266.com forum
-- MIT license, http://opensource.org/licenses/MIT
--Support list:
--DHT11 Tested
--DHT21 Not Test yet
--DHT22(AM2302) Tested
--AM2320 Not Test yet
--Output format-> Real temperature times 10(or DHT22 will miss it float part in Int Version)
--==========================Module Part======================
local moduleName = ...
local M = {}
_G[moduleName] = M
--==========================Local the UMI and TEMP===========
local humidity
local temperature
--==========================Local the bitStream==============
local bitStream = {}
---------------------------Read bitStream from DHTXX--------------------------
local function read(pin)
  local bitlength = 0
  humidity = 0
  temperature = 0
  -- Use Markus Gritsch trick to speed up read/write on GPIO
  local gpio_read = gpio.read
  for j = 1, 40, 1 do
    bitStream[j] = 0
  -- Step 1:  send out start signal to DHT22
  gpio.mode(pin, gpio.OUTPUT)
  gpio.write(pin, gpio.HIGH)
  tmr.delay(100)
  gpio.write(pin, gpio.LOW)
  tmr.delay(20000)
  gpio.mode(pin, gpio.INPUT)
  -- Step 2:  Receive bitStream from DHT11/22
  -- bus will always let up eventually, don't bother with timeout
  while (gpio_read(pin) == 0 ) do end
  local c=0
  while (gpio_read(pin) == 1 and c < 500) do c = c + 1 end
  c=0
  -- Step 3: DHT22 send data
  for j = 1, 40, 1 do
    while (gpio_read(pin) == 1 and bitlength < 10 ) do
      bitlength = bitlength + 1
    bitStream[j] = bitlength
    bitlength = 0
    while (gpio_read(pin) == 0) do end
---------------------------Check out the data--------------------------
----Auto Select the DHT11/DHT22 By check the byte[1] && byte[3] -------
---------------Which is empty when using DHT11-------------------------
function M.read(pin)
  read(pin)
  local byte_0 = 0
  local byte_1 = 0
  local byte_2 = 0
  local byte_3 = 0
  local byte_4 = 0
  for i = 1, 8, 1 do -- Byte[0]
    if (bitStream[i] > 3) then
      byte_0 = byte_0 + 2 ^ (8 - i)
  for i = 1, 8, 1 do -- Byte[1]
    if (bitStream[i+8] > 3) then
      byte_1 = byte_1 + 2 ^ (8 - i)
  for i = 1, 8, 1 do -- Byte[2]
    if (bitStream[i+16] > 3) then
      byte_2 = byte_2 + 2 ^ (8 - i)
  for i = 1, 8, 1 do -- Byte[3]
    if (bitStream[i+24] > 3) then
  for i = 1, 8, 1 do -- Byte[4]
    if (bitStream[i+32] > 3) then
      byte_4 = byte_4 + 2 ^ (8 - i)
  if byte_1==0 and byte_3 == 0 then
  ---------------------------Convert the bitStream into Number through DHT11's Way--------------------------
  --As for DHT11 40Bit is consisit of 5Bytes
  --First byte->Humidity Data's Int part
  --Sencond byte->Humidity Data's Float Part(Which should be empty)
  --Third byte->Temp Data;s Intpart
  --Forth byte->Temp Data's Float Part(Which should be empty)
  --Fifth byte->SUM Byte, Humi+Temp
    if(byte_4 ~= byte_0+byte_2) then
     humidity = nil
     temperature = nil
     humidity = byte_0 *10 -- In order to universe with the DHT22
     temperature = byte_2 *10
  else ---------------------------Convert the bitStream into Number through DHT22's Way--------------------------
  --As for DHT22 40Bit is consisit of 5Bytes
  --First byte->Humidity Data's High Bit
  --Sencond byte->Humidity Data's Low Bit(And if over 0x8000, use complement)
  --Third byte->Temp Data's High Bit
  --Forth byte->Temp Data's Low Bit
  humidity = byte_0 * 256 + byte_1
  temperature = byte_2 * 256 + byte_3
  checksum = byte_4
  checksumTest = (bit.band(humidity, 0xFF) + bit.rshift(humidity, 8) + bit.band(temperature, 0xFF) + bit.rshift(temperature, 8))
  checksumTest = bit.band(checksumTest, 0xFF)
  if temperature > 0x8000 then
    -- convert to negative format
    temperature = -(temperature - 0x8000)
  -- conditions compatible con float point and integer
  if (checksumTest - checksum >= 1) or (checksum - checksumTest >= 1) then
    humidity = nil
   byte_0 = nil
   byte_1 = nil
   byte_2 = nil
   byte_3 = nil
   byte_4 = nil
--------------API for geting the data out------------------
function M.getTemperature()
  return temperature
function M.getHumidity()
  return humidity
-------------Return Index------------------------------------
return M
By jankop
#30475 Try to replace all the characters "[" and "]" in all the comments. It my by your problem.
edit: I am test it with Lualoader. Upload Binary is OK, but Upload Text is wrong -> stdin:1: ')' expected near ']'
Example:
Code: Select all----Auto Select the DHT11/DHT22 By check the byte[1] && byte[3] -------
change to
----Auto Select the DHT11/DHT22 By check the byte*1* && byte*3* -------
