MQTT code bug
Posted: Sat Oct 31, 2015 2:24 am
i'm having a problem with the code below when i execute it line by line it works fine but when i click "save to esp" it shows that error "init.lua:29: not connected"
code
wifi.setmode(wifi.STATION)
wifi.sta.config("IOTsMartHome","12345678")
ip = wifi.sta.getip()
print(ip)
--init mqtt client with keepalive timer 120sec
m = mqtt.Client("clientid", 120, "user", "password")
--setup Last Will and Testament (optional)
--Broker will publish a message with qos = 0, retain = 0, data = "offline"
--to topic "/lwt" if client don’t send keepalive packet
m:lwt("/lwt", "offline", 0, 0)
m:on("connect", function(con) print ("connected") end)
m:on("offline", function(con) print ("offline") end)
--on publish message receive event
m:on("message", function(conn, topic, data)
print(topic .. ":" )
if data ~= nil then
print(data)
end
end)
--for secure: m:connect("192.168.11.118", 1880, 1)
m:connect("192.168.1.6", 1883, 0, function(conn) print("connected") end)
--subscribe topic with qos = 0
m:subscribe("/call",0, function(conn) print("subscribe success") end)
--publish a message with data = hello, QoS = 0, retain = 0
m:publish("/topic","hello",0,0, function(conn) print("sent") end)
m:close();
--you can call m:connect again
code
print(ip)
if data ~= nil then
print(data)
end
end)
m:close();
