device_id = "553CDA2DEAC90"
query_id = ""
dim = 120
wifi.setmode(wifi.STATION)
wifi.sta.config("SSID","PASSWORD")
wifi.sta.connect()
wifi.sta.setip({ip="10.0.0.122",netmask="255.255.255.0",gateway="10.0.0.2"})
outpin = 7 --GPIO13
gpio.mode(outpin,gpio.OUTPUT)
gpio.write(outpin,gpio.LOW)
inpin = 6 --GPIO12
gpio.mode(inpin,gpio.INT,gpio.PULLUP)
function zero_cross()
dt = 75*dim
tmr.delay(dt)
gpio.write(outpin,gpio.HIGH)
tmr.delay(1)
tmr.wdclr()
gpio.trig(inpin,"up",zero_cross)
function sendData()
if(wifi.sta.status() == 5)then
conn=net.createConnection(net.TCP, 0)
conn:connect(PORT,'IP')
if(firstStart == 0)then
conn:send(device_id)
conn:send("|0|")
if(query_id == nil)then
conn:send("|0|")
conn:send(dim)
conn:send("|")
conn:send(query_id)
conn:send("|")
conn:send(dim)
query_id = nil
conn:on("receive", function(conn, payload)
payload = string.gsub(payload, " ", "")
dim = string.sub(payload, 0, string.find(payload, "|")-1)
payload = string.gsub(payload, dim.."|", "")
query_id = payload
conn:close()
end)
wifi.sta.connect()
tmr.alarm(6, 1000, 1, sendData )The problem that I am facing is that when at the bottom of the script I start tmr.alarm()... But the under the function zero_cross() its uses tmr.delay and that seems to make tmr.alarm() not function anymore. All that happens is the ESP just keeps on restarting. If I run the above code seperate (just the dimming function or just the sendData function then everything works perfect). Does anyone have any suggestions?
