PANIC: unprotected error in call to Lua API (init.lua:98: need <256 payload)
It does not look like an error caused by lhttpd, I assume in the Lua API there's a limit of 256 chars.
Explore... Chat... Share...
gerardwr wrote:In the lhhtpd webserver I get the following PANIC error when I want to send a later set of chars with conn:send.Code: Select allPANIC: unprotected error in call to Lua API (init.lua:98: need <256 payload)
zeroday wrote:It's from API. for memory consideration.
will change to 1460 in next build.
