By andrewtholt
#39583 Hi,
I am new to nodeMCU, so this might be me
I'm seeing a memory leek in the MQTT client in NodeMCU 0.9.6 build 20150704
Here is my code, below
So it connects, and disconnects from an MQTT instance triggered by a timer.
What I see is the heap space gradually dropping until it reaches a critical level and then a reset.
The file is called "application.lua"
I run it with
Code: Select allapp=require("application")
app.start()
It's possible I'm doing something stupid, or maybe there is a leak
Regards,
Andrew
Code: Select alllocal module = {}
local function run()
    print("Heap start:" .. node.heap())
    if wifi.sta.status() == 5 and wifi.sta.getip() ~= nil then
        print("Connected")
        m = mqtt.Client(config.ID, 120)
        m:connect(config.HOST, config.PORT, 0, 1, function(con)
            print("Connected")
        end)
        m:close()
        m = nil
        print ("Not connected")
    print("Heap end  :" .. node.heap())
local function test()
    print("Tick ...")
function module.start()
    tmr.stop(6)
    tmr.alarm(6,1000,1, run)
return module
