Can not connect to MQTT hub
PostPosted: Wed Feb 03, 2016 5:12 am
by Andrey Andrev
Hi, I am trying to connect my local mosquitto server using mqtt lib and following code provides no output at all:
Code: Select allm=mqtt.Client("nodemcu_box", 120)
m:connect("192.168.1.3", 1883, 0, function(conn)
    print("connected")
end)
m:publish("hello/world","hello from nodemcu",0,0, function(conn)
    print("sent")
end)
but I can send messages to the broker using console client
Code: Select all$ mosquitto_pub -h 192.168.1.3 -p 1883 -d -t hello/world -m "hello"
and receive it if I subscribe to topic.
What might be the reason why it is not working from nodemcu?
Re: Can not connect to MQTT hub
PostPosted: Tue Feb 16, 2016 6:06 am
by Viriato
Hi,
I have the same issue , did you found a solution ?
My setup is the following :
- I am using Pi 2 as a broker , with mosquito installed
- client on PC - work correctly both ways
- client on Android - work correctly both ways
But Can't connect with ESP8266 - firmware 0.9.6
Any suggestion on this issue ?
Thanks
