I have a problem which I cannot understand.
I am not very experienced in NodeMCU so I might have missed something obvious, but I have ran out of ideas hence me asking.
I have a piece of working code which uploads temperature from a DS18B20 onto a website.
There is a tmr alarm for uploads at regular intervals and two further uploads which can be triggered by two pushbuttons through interrupts.
The code works perfectly if I launch the script via ESPlorer by clicking on the file.
However, when I call the script from init.lua the regular uploads work but when the two buttons are being pressed nothing is detected.
I am using the following firmware:
NodeMCU 0.9.6 build 20150704 powered by Lua 5.1.4
the code is below. There is still is some repeated code but it serves the purpose of demonstrating the problem:
init.lua:
wifi.setmode(wifi.STATION)
wifi.sta.config("aSSID","aPWD")
tmr.alarm(1, 1000, 1, function()
if wifi.sta.getip()== nil then
print("IP unavaiable, Waiting...")
tmr.stop(1)
print("Config done, IP is "..wifi.sta.getip())
dofile("mainUpload.lua")
end)mainUpload.lua
local str = 0
local tmrSecond = 1000 -- microseconds
local minute = 60000 -- milliseconds
local debounce = 0.2 * tmrSecond
local sensorNo = 1
local tempUploadInterval = 30 * tmrSecond
local theKey = "key=abba"
local webSite = "a-web-server.com" -- ##### Change This
-- MAIN
print("")
print("Started the main program:")
print(" ### Temperature Sensor # 1, SSID = " .. wifi.sta.getconfig())
print("")
gpio.mode(7,gpio.INT,gpio.PULLUP) -- Pushbutton 1
gpio.trig(7, "low",onSwitch_1_Detection) -- interrupt
gpio.mode(2,gpio.INT,gpio.PULLUP) -- Pushbutton 2
gpio.trig(2, "low",onSwitch_2_Detection) -- interrupt
-- Temperature Detection loop
tmr.alarm(0, tempUploadInterval, 1, function()
print(" ")
t=require("ds18b20")
local dataStr = (theKey ..
"&sensorNo=" .. tostring(sensorNo) ..
"&tooHot=0" ..
"&tooCold=0" ..
"&temperature=" .. t.readNumber(6))
local sendStr = ("POST /log-room-temperature.php HTTP/1.1\r\n"..
"Host: " .. webSite .. "\r\n"..
"Accept: */*\r\n"..
"Content-Type: application/x-www-form-urlencoded\r\n"..
"Content-Length: " .. tostring(string.len(dataStr)) .."\r\n\r\n"..
dataStr ..
"\r\n\r\n")
print(sendStr)
conn=net.createConnection(net.TCP, 0)
conn:on("connection",function(conn, payload)
conn:send(sendStr)
end)
conn:on("receive", function(conn, payload)
print(payload)
conn:close()
end)
conn:connect(80,webSite)
-- Release after use
t = nil
ds18b20 = nil
package.loaded["ds18b20"]=nil
--print(dataStr)
end)
function onSwitch_1_Detection(level)
if level < 1 then
tmr.delay(debounce)
print("---> Switch 1 PRESSED <--")
print(" ")
"&tooHot=1" ..
"&tooCold=0" ..
"Accept: */*\r\n"..
dataStr ..
"\r\n\r\n")
print(sendStr)
conn:send(sendStr)
end)
print(payload)
conn:close()
end)
t = nil
ds18b20 = nil
--print(dataStr)
tmr.delay(debounce)
print("---> Switch 1 RELEASED <--")
print(" ")
function onSwitch_2_Detection(level)
if level <1 then
tmr.delay(debounce)
print("---> Switch 2 PRESSED <--")
print(" ")
"&tooHot=0" ..
"&tooCold=1" ..
"Accept: */*\r\n"..
dataStr ..
"\r\n\r\n")
print(sendStr)
conn:send(sendStr)
end)
print(payload)
conn:close()
end)
t = nil
ds18b20 = nil
--print(dataStr)
tmr.delay(debounce)
print("---> Switch 2 RELEASED <--")
print(" ")
endCould anyone please help?
Many Thanks
Riccardo
