What am I doing wrong? See following lua code. It works, but only for few minutes. I tested various firmware versions also various branches, but results are approximately the same. Nodemcu hangs after few minutes. It should work as an external thermometer but becouse of stability it is unusable.
file: main.lua
wifi.setmode(wifi.STATION)
wifi.setphymode(wifi.PHYMODE_N)
wifi.sta.config('WIFI_SSID', 'wifi_passwd')
wifi.sta.connect()
wifi.sta.setip({ip='192.168.2.254',netmask='255.255.255.0',gateway='192.168.2.1'})
function loop()
if wifi.sta.status() == 5 then
m = mqtt.Client('nodemcu',120,'mqtt_user','mqtt_password')
m:connect('192.168.2.2', 1883, 0, 1, function(conn)
tmr.stop(0)
local status, temp, humi, temp_dec, humi_dec = dht.read(4)
local temperature = string.format("%d.%03d", math.floor(temp), temp_dec)
local humidity = string.format("%d.%03d", math.floor(humi), humi_dec)
local a = {}
a["temperature"] = temperature;
a["humidity"] = humidity;
m:publish("/nodemcu/dht22", cjson.encode(a) ,0,0, function(conn)
m:close()
wifi.sta.disconnect()
node.dsleep(60000000)
end)
end)
tmr.alarm(0, 500, 1, function() loop() end)
file: init.lua
dofile('main.lua')
collectgarbage()
And this is the output from serial console (my latest attempt,it is not so much helpful):
NodeMCU custom build by frightanic.com
branch: master
commit: c8037568571edb5c568c2f8231e4f8ce0683b883
SSL: false
modules: file,gpio,mqtt,net,node,tmr,uart,wifi
build built on: 2016-02-29 17:42
powered by Lua 5.1.4 on SDK 1.4.0
> 0�~?�4�!� [�$��2: �� �� O�:��>�� �R
branch: master
SSL: false
branch: master
SSL: false
> 0�~?�4�
