- Sat Jan 31, 2015 2:24 pm
#8637
jim121049 wrote:You don't need to mess with your router. Just plug your write key into line 4 below.
Code: Select all--once every 10 minutes send temperature from DS18B20 to thingspeak.com
WRITEKEY = "YOURWRITEKEYGOESHERE"
INTERVAL = 10 -- every 10 minutes
-- GPIO0 = 3
-- GPIO1 = 10
-- GPIO2 = 4
-- GPIO3 = 9
-- GPIO4 = 1
-- GPIO5 = 2
-- GPIO9 = 11
-- GPIO10 = 12
-- GPIO12 = 6
-- GPIO13 = 7
-- GPIO14 = 5
-- GPIO15 = 8
-- GPIO16 = 0
GPIO2 = 4 -- use GPIO2 for 1-wire
function findaddress()
local count = 0
repeat
count = count + 1
addr = ow.reset_search(GPIO2)
addr = ow.search(GPIO2)
tmr.wdclr()
until((addr ~= nil) or (count > 100))
if count > 100 then
return nil
return addr
function readtemp(address)
--print(addr:byte(1,8))
local data = nil
local crc = ow.crc8(string.sub(addr,1,7))
if (crc == addr:byte(8)) then
if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28)) then
--print("Device is a DS18S20 family device.")
ow.reset(GPIO2)
ow.select(GPIO2, addr)
ow.write(GPIO2,0x44,1)
tmr.delay(1000000)
present = ow.reset(GPIO2)
ow.write(GPIO2,0xBE,1)
data = string.char(ow.read(GPIO2))
for i = 1, 8 do
data = data .. string.char(ow.read(GPIO2))
--print(data:byte(1,9))
crc = ow.crc8(string.sub(data,1,8))
--print("CRC="..crc)
if (crc == data:byte(9)) then
-- read temperature
f1 = data:byte(1)+data:byte(2)*256
if (f1 > 32768) then -- for negative termperatures
f1 = (bxor(f1, 0xffff)) + 1
f1 = (-1) * f1
-- convert Celsius to Fahrenheit
f1=(((f1*625)*9)/500)+3200
f2 = f1/100 -- integer part of Fahrenheit temperature
f3 = f1%10 -- fractional part of Fahrenheit temperature (use %100 for 2 decimal places)
--print("Temp = "..f2.."."..f3.." F.")
end -- if (crc == data:byte(9)) then
tmr.wdclr()
--print("Device family is not recognized.")
return nil
end -- if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28)) then
--print("CRC is not valid!")
return nil
end -- if (crc == addr:byte(8)) then
return f2.."."..f3
function sendtothingspeak(temp)
local conn=net.createConnection(net.TCP, 0)
conn:connect(80,'184.106.153.149')
conn:send("GET /update?key="..WRITEKEY.."&field1="..temp.." HTTP/1.1\r\n")
conn:send("Host: api.thingspeak.com\r\n")
conn:send("Accept: */*\r\n")
conn:send("User-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n\r\n")
conn:on("receive", function(conn, payload)
for line in payload:gmatch("[^\r\n]+") do -- split "payload" into lines
if string.find(line,"HTTP/1.1") ~= nil then
print(line)
break
conn:close()
conn=nil
line=nil
payload=nil
end) -- conn:on("receive", function(conn, payload)
ow.setup(GPIO2)
ds18b20addr=findaddress()
if ds18b20addr ~= nil then
tmr.alarm(0,1000*60*INTERVAL,1,function() -- fire timer every 10 minutes...
temp = readtemp(ds18b20addr)
if temp ~= nil then
print(node.heap().." bytes")
print(temp.." F")
print("crc error")
end -- if temp ~= nil
end) -- tmr.alarm(0,1000*60,1,function()
print("DS18B20 not found!")
end -- if ds18b20addr ~= nil then
Could please somebody check if the code is working for you? Don't get me wrong, jim121049
but I really don't know what could be wrong with my setup... Thank you very much!
