By alonewolfx2
#3902 thank you for sharing. I did some test. firstly it's working with lua request like this :D
Code: Select all<?lua print("Free Ram: "..node.heap().."<br>") print("Chip Id: "..node.chipid()) ?>
or
Code: Select all<?lua if (gpio.read(0) == 1) then print("high"); else print("low"); end ?><br>
   <?lua if (gpio.read(1) == 1) then print("high"); else print("low"); end ?>
but post request not working. and its crashing when wrong file request like " test.html". we need some change.
By gerardwr
#3904
alonewolfx2 wrote:thank you for sharing. I did some test. firstly it's working with lua request like this :D
or
That's excellent news!
Will test later today. If this works as expected I will stop development on my own webserver, and continue with the migrated elua code.
How about you?
By alonewolfx2
#3906
or
How about you?
Agree. My favorite part of the elua webserver is just filename sending to the uart.and can be turned off.
Code: Select all.v,...ZbRS JzD@JStbgz
NodeMcu 0.9.2 build 20141202  powered by Lua 5.1.4
> index.html
index.pht
i think we could continue from elua. Here is to do list
1- Get or Post request handling
2- Adding some security
By alonewolfx2
#3910 Some more test.
Code: Select all--startup heap and after every request
> @xSG.1.~.LC.   Jzbgf.hbcz
> print(node.heap())
9720
> index.pht
print(node.heap())
8912
> index.pht
print(node.heap())
8864
> index.pht
index.pht
print(node.heap())
8720
> index.pht
print(node.heap())
9256
--- after a couple file not found
> index.tpl
index.tpl
print(node.heap())
8680
> index.tpl
print(node.heap())
7464
> index.tpl
index.tpl
index.tpl
print(node.heap())
7408
> print(node.heap())
7840
> print(node.heap())
8592
it seems heap recovering to fast. and i tried pc with android same time,same page request. but it seems not working with multiple request.
