fx=function() print("Mem free: "..tostring(node.heap()) ) end
s=string.dump(fx)
print(#s)
204 byte
M.setapi=function (tab,callb) M.apifunc=callb end
144 byte
Not bad, but you should count bytes!
Forth? Who can port Forth to this chip ?..
Explore... Chat... Share...
s=string.dump(fx)
print(#s)
NodeMCU 0.9.5 build 20150118 powered by Lua 5.1.4
> for n,s in pairs(file.list()) do print(n.." size: "..s) end
log.txt size: 17
index.html size: 230
lhttpd.lua size: 3020
index.pht size: 848
> dofile("lhttpd.lua")
lhttpd.lua:1: unexpected symbol near '?'
ozayturay wrote:Using ESPlorer v0.1 build 206 on a ESP03 module I'm getting unexpected symbol error. The only modification i made is renaming init.lua file to lhttpd.luaCode: Select allNodeMCU 0.9.5 build 20150118 powered by Lua 5.1.4
log.txt size: 17
index.pht size: 848
Any ideas?
