By EnfRoll
#7957 Hello, I want to do a complete library management 128x64 OLED display. I tried to make it based on the library from Adafruit, but I had problems with rendering pixels :(
oled.lua (lib)
Code: Select alllocal moduleName = ...
local M = {}
_G[moduleName] = M
oled_id = 0
oled_gpio = {[0]=3,[2]=4,[4]=2,[5]=1,[12]=6,[13]=7,[14]=5}
oled_sda = oled_gpio[0]
oled_scl = oled_gpio[2]
oled_addr = 0x3C
dofile("ascii.lua")
function write_reg(dev_addr, reg_addr, reg_val)
     i2c.start(oled_id)
     i2c.address(oled_id, dev_addr, i2c.TRANSMITTER)
     i2c.write(oled_id, reg_addr)
     i2c.write(oled_id, reg_val)
     i2c.stop(oled_id)
function oled_command(cmd)
     write_reg(oled_addr, 0, cmd)
function M.init(sda_n, scl_n)
     oled_sda = oled_gpio[sda_n]
     oled_scl = oled_gpio[scl_n]
     i2c.setup(oled_id, oled_sda, oled_scl, i2c.SLOW)
     oled_command(0x8d)
     oled_command(0x14)
     oled_command(0xaf)
     oled_command(0xd3)
     oled_command(0x00)
     oled_command(0x40)
     oled_command(0xa1)
     oled_command(0xc8)
     oled_command(0xda)
     oled_command(0x12)
     oled_command(0x81)
     oled_command(0xff)
     oled_command(0x20)
     oled_command(0x02)
function M.on()
     oled_command(0xAF)
function M.off()
     oled_command(0xAE)
function M.invert(state)
     if state == 1 then
          oled_command(0xA7)
          oled_command(0xA6)
function M.scroll(start, stop, left)
     if left then
          oled_command(0x26)
          oled_command(0x27)
     oled_command(0X00)
     oled_command(start)
     oled_command(0X00)
     oled_command(stop)
     oled_command(0X00)
     oled_command(0XFF)
     oled_command(0x2F)
function M.scroll_stop()
     oled_command(0x2E)
function M.set_pos(x, y)
     xp = bit.band(x, 0xf0)
     xp = bit.rshift(xp, 4)
     xp = bit.bor(xp, 0x10)
     xr = bit.band(x, 0x0f)
     xr = bit.bor(xr, 0x01)
     oled_command(0xB0+y)
     oled_command(xp)
     oled_command(xr)
function M.clear()
     oled_command(0x20)
     oled_command(0x01)
     for i=0,1024 do
          write_reg(oled_addr, 0x40, 0x00)
          tmr.wdclr()
     oled_command(0x20)
     oled_command(0x02)
function M.write_char(char)
     for ic=0,4 do
          write_reg(oled_addr, 0x40, ascii[char][ic])
          tmr.wdclr()
function M.write_word(_word)
     _wc = 1
     while _word[_wc] do
          M.write_char(_word[_wc])
          _wc=_wc+1
return M
ascii.lua (for char printing) (not full)
Code: Select allascii = {}
ascii[0] = {}
ascii[0][0] = 0x3e
ascii[0][1] = 0x51
ascii[0][2] = 0x49
ascii[0][3] = 0x45
ascii[0][4] = 0x3e
ascii[1] = {}
ascii[1][0] = 0x00
ascii[1][1] = 0x42
ascii[1][2] = 0x7f
ascii[1][3] = 0x40
ascii[1][4] = 0x00
ascii[2] = {}
ascii[2][0] = 0x42
ascii[2][1] = 0x61
ascii[2][2] = 0x51
ascii[2][3] = 0x49
ascii[2][4] = 0x46
ascii[3] = {}
ascii[3][0] = 0x21
ascii[3][1] = 0x41
ascii[3][2] = 0x45
ascii[3][3] = 0x4b
ascii[3][4] = 0x31
ascii[4] = {}
ascii[4][0] = 0x18
ascii[4][1] = 0x14
ascii[4][2] = 0x12
ascii[4][3] = 0x7f
ascii[4][4] = 0x10
ascii[5] = {}
ascii[5][0] = 0x27
ascii[5][1] = 0x45
ascii[5][2] = 0x45
ascii[5][3] = 0x45
ascii[5][4] = 0x39
ascii[6] = {}
ascii[6][0] = 0x3c
ascii[6][1] = 0x4a
ascii[6][2] = 0x49
ascii[6][3] = 0x49
ascii[6][4] = 0x30
ascii[7] = {}
ascii[7][0] = 0x01
ascii[7][1] = 0x71
ascii[7][2] = 0x09
ascii[7][3] = 0x05
ascii[7][4] = 0x03
ascii[8] = {}
ascii[8][0] = 0x36
ascii[8][1] = 0x49
ascii[8][2] = 0x49
ascii[8][3] = 0x49
ascii[8][4] = 0x36
ascii[9] = {}
ascii[9][0] = 0x06
ascii[9][1] = 0x49
ascii[9][2] = 0x49
ascii[9][3] = 0x29
ascii[9][4] = 0x1e
ascii["H"] = {}
ascii["H"][0] = 0x7f
ascii["H"][1] = 0x08
ascii["H"][2] = 0x08
ascii["H"][3] = 0x08
ascii["H"][4] = 0x7f
ascii["e"] = {}
ascii["e"][0] = 0x38
ascii["e"][1] = 0x54
ascii["e"][2] = 0x54
ascii["e"][3] = 0x54
ascii["e"][4] = 0x18
ascii["l"] = {}
ascii["l"][0] = 0x00
ascii["l"][1] = 0x41
ascii["l"][2] = 0x7f
ascii["l"][3] = 0x40
ascii["l"][4] = 0x00
ascii["o"] = {}
ascii["o"][0] = 0x38
ascii["o"][1] = 0x44
ascii["o"][2] = 0x44
ascii["o"][3] = 0x44
ascii["o"][4] = 0x38
ascii["("] = {}
ascii["("][0] = 0x00
ascii["("][1] = 0x1c
ascii["("][2] = 0x22
ascii["("][3] = 0x41
ascii["("][4] = 0x00
ascii[")"] = {}
ascii[")"][0] = 0x00
ascii[")"][1] = 0x41
ascii[")"][2] = 0x22
ascii[")"][3] = 0x1c
ascii[")"][4] = 0x00
example.lua (SDA and SCL setted to ESP-01 "0" and "2" GPIO's)
Code: Select alloled = require("oled")
oled.init(0, 2)
oled.set_pos(75, 3) -- set cursor to 75, 3
we = {"H","e","l","l","o","(","l","o","l",")"}
oled.write_word(we) -- write Hello(lol)
oled.scroll(0x00, 0x0f) -- start scroll
state = 0
tmr.alarm(3, 500, 1, function() -- invert every 0.5s
     oled.invert(state)
     state = bit.bxor(state, 1)
end)
tmr.alarm(4, 3000, 0, function() -- stop scroll and clear after 4 sec
     tmr.stop(3)
     oled.scroll_stop()
     oled.clear()
     oled.invert(0)
end)
update (23.01.2015): added text printing support, cursor position, clear
By gwizz
#7959 That's good work, thanks for sharing!
Can I suggest that you post in one of the previous threads rather than continuing a new one - or maybe an admin can merge this thread with this one: http://www.esp8266.com/viewtopic.php?f=24&t=1318
Especially as you are extending the code of our previous work - plus it keeps the information in one place.
Cheers!
By alonewolfx2
#7968 it's different module and it's completely different. merge not necessary.
gwizz wrote:That's good work, thanks for sharing!
Cheers!
By gwizz
#7983 It's true that the other thread started off talking about some different oled module, but the second half was talking about this 1306 based one.
No worries, your call, I was just thinking about the people mentioning that information was scattered around various posts. I suppose I should make a wiki article.
