I have some 1wire temperature sensors. Some DS18B20 and some DS18S20
I've noticed that the DS18B20 one wire module for NODEMCU available here:
https://github.com/nodemcu/nodemcu-firm ... s18b20.lua
works fine with both sensor types, however the temperature reading for the DS18S20 is 9 bits only (12 bits for the DS18B20).
9 bits is default for DS18S20 however it's possible to have 12 bits as explained here:
https://datasheets.maximintegrated.com/ ... S18S20.pdf
and here in this Maxim application note: comparison of both sensors
https://www.maximintegrated.com/en/app- ... vp/id/4377
9 bits is annoying because you get only half degree precision (i.e. 22; 22.5; 23; 23.5; 24 etc..) you cannot get something like 22.3. So even if I don't need the 4 figures after the decimal point, 12 bits resolution is better.
I have slightly modified the ds18b20.lua script to have this fonctionnality here is the change:
line 108:
t = t * 5000 -- DS18S20, 1 fractional bitreplaced by 6 lines:
-- 12 bits resolution. If you need 9 bits only comment the
-- two following lines and un-comment the third
c = (((data:byte(8)-data:byte(7))/data:byte(8)) - 0.25) * 10000
t = (t * 5000) + c
-- t = t * 5000 -- DS18S20, 1 fractional bithere is the full script. Hope it may help others...
-- DS18B20 one wire module for NODEMCU
-- NODEMCU TEAM
-- LICENCE: http://opensource.org/licenses/MIT
-- Vowstar <vowstar@nodemcu.com>
-- 2015/02/14 sza2 <sza2trash@gmail.com> Fix for negative values
-- Set module name as parameter of require
local modname = ...
local M = {}
_G[modname] = M
-- Local used variables
-- DS18B20 dq pin
local pin = nil
-- DS18B20 default pin
local defaultPin = 9
-- Local used modules
-- Table module
local table = table
-- String module
local string = string
-- One wire module
local ow = ow
-- Timer module
local tmr = tmr
-- Limited to local environment
setfenv(1,M)
-- Implementation
C = 'C'
F = 'F'
K = 'K'
function setup(dq)
pin = dq
if(pin == nil) then
pin = defaultPin
ow.setup(pin)
function addrs()
setup(pin)
tbl = {}
ow.reset_search(pin)
repeat
addr = ow.search(pin)
if(addr ~= nil) then
table.insert(tbl, addr)
tmr.wdclr()
until (addr == nil)
return tbl
function readNumber(addr, unit)
result = nil
setup(pin)
flag = false
if(addr == nil) then
count = 0
repeat
count = count + 1
tmr.wdclr()
until((addr ~= nil) or (count > 100))
return result
crc = ow.crc8(string.sub(addr,1,7))
if (crc == addr:byte(8)) then
if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28)) then
-- print("Device is a DS18S20 family device.")
ow.reset(pin)
ow.select(pin, addr)
ow.write(pin, 0x44, 1)
-- tmr.delay(1000000)
present = ow.reset(pin)
ow.write(pin,0xBE,1)
-- print("P="..present)
data = nil
data = string.char(ow.read(pin))
for i = 1, 8 do
data = data .. string.char(ow.read(pin))
-- print(data:byte(1,9))
crc = ow.crc8(string.sub(data,1,8))
-- print("CRC="..crc)
if (crc == data:byte(9)) then
t = (data:byte(1) + data:byte(2) * 256)
if (t > 32767) then
t = t - 65536
if (addr:byte(1) == 0x28) then
t = t * 625 -- DS18B20, 4 fractional bits
t = (t * 5000) + c
if(unit == nil or unit == 'C') then
-- do nothing
elseif(unit == 'F') then
t = t * 1,8 + 320000
elseif(unit == 'K') then
t = t + 2731500
return nil
t = t / 10000
return t
tmr.wdclr()
-- print("Device family is not recognized.")
-- print("CRC is not valid!")
return result
function read(addr, unit)
t = readNumber(addr, unit)
if (t == nil) then
return nil
return t
-- Return module table
return M--
Jmp0
