dofile("ug8.lua")
--- Starting Rotation Test ---
ug8.lua:43: attempt to index global 'disp' (a nil value)
The code example is from
https://github.com/nodemcu/nodemcu-firm ... tation.lua
Any help is welcome
Regards
Explore... Chat... Share...
> for n,s in pairs(file.list()) do print(n.." size: "..s) end
u8g_rotation.lua size: 2052
u8g_rook.bm size: 9
u8glib_logo.xbm size: 121
> =node.heap()
21480
> dofile("u8g_rotation.lua")
--- Rotation Test done ---
> =node.heap()
13992
> =disp
userdata: 0x3fff71a0
--init_i2c_display()
init_spi_display()
rotation_test()It takes about 20-25 seconds for home assistant c[…]
