Just thought I'd share a WOL implementation, used to boot a PC over the local LAN. Its based on the code found here: https://gist.github.com/maiconio/2865500
Note that your target machine needs to be setup to accept this packet. Typically this calls for both a BIOS and network adapter settings change (the latter is in your operating system / device manager, etc.). Google is helpful to get this setup.
wolcon=net.createConnection(net.UDP, 0) --Not tested with TCP. UDP works fine
wolcon:connect(9,"255.255.255.255") --Magic packet is broadcast. Can also limit to broadcast address of your own network
mac1=string.char(0xe0,0x69,0x95,0xab,0x36,0xe7) -- Insert MAC address here of target machine
for i=1,4 do
mac1 = mac1..mac1 --Magic packet requires 16x target PC MAC as payload
mac2 = string.char(0xff,0xff,0xff,0xff,0xff,0xff)..mac1 --Magic packet needs broadcast MAC in front
wolcon:send(mac2) --Send magic packet
print("Wake-On-Lan packet sent")
wolcon:close()
collectgarbage();Enjoy!
