By Cobozco
#18760 Hello and thanks for whoever takes the time to read this - I've been working on this to no success for the past couple weeks for school. Basic ways to use Mosquitto on the Raspberry Pi to publish/subscribe to the ESP2866 on the NodeMCU - visa versa.
In terms of the node I`ve tried the test and example code posted herehttp://www.esp8266.com/viewtopic.php?f=19&t=1278
Code: Select all-- init mqtt client with keepalive timer 120sec
m = mqtt.Client(wifi.sta.getmac(), 120,  Bakery229, electronics229)
-- Broker will publish a message with qos = 0, retain = 0, data = "offline"
-- to topic "/lwt" if client don't send keepalive packet
m:lwt("/lwt", "offline", 0, 0)
 print("lwt went through" )
m:on("connect", function(con) print ("connected") end)
 print("m:on connect went through" )
m:on("offline", function(con) print ("offline") end)
print("m:on offline went through" )
-- on publish message receive event
m:on("message", function(conn, topic, data)
  print(topic .. ":" )
  if data ~= nil then
    print(data)
end)
-- for secure: m:connect("192.168.0.102", 1883, 1)
m:connect("192.168.0.102", 1883, 0, function(conn) print("connected") end)
-- subscribe topic with qos = 0
m:subscribe("/test",0, function(conn) print("subscribe success") end)
-- publish a message with data = hello, QoS = 0, retain = 0
m:publish("/test","hello",0,0, function(conn) print("sent") end)
m:close();
-- you can call m:connect again
Here's my output:
> dofile("test270515.lua")
lwt went through
test270515.lua:21: not connected
> offline
In terms of R.Pi
I'm running two separate terminal windows one running a subscribing mosquittto line, and another publishing
mosquitto_sub -h 192.168.0.102 -p 1883 -t /#
while true; do mosquitto_pub -h 192.168.0.102 -p 1883 -t /test -m Hi; done
I'm getting the message sent through to the other terminal, however nothing for the NodeMCU
Thanks again if you're willing to help
By Cobozco
#18761 Yikes, realized I didn't connect to the network initally...
Code: Select allSSID = "Bakery229"
password = "electronics229"
wifi.setmode(wifi.STATION)
wifi.sta.config(SSID, password)
wifi.sta.connect()
print("ESP8266 mode is: " .. wifi.getmode())
print("The module MAC address is: " .. wifi.ap.getmac())
print("Config done, IP is "..wifi.sta.getip())
m = mqtt.Client(wifi.sta.getmac(), 120)
m:lwt("/lwt", wifi.sta.getmac(), 0, 0)
     print ("reconnecting...")
     print(node.heap())
     tmr.alarm(1, 10000, 0, function()
          m:connect("192.168.0.102", 1883, 0)
     end)
end)
m:on("It works", function(conn, topic, data)
  if data ~= nil then
    print(data)
end)
tmr.alarm(0, 1000, 1, function()
 if wifi.sta.status() == 5 then
     tmr.stop(0)
          print("connected")
          end)
     end)
end)
Tried implementing the example code below the "test" code given again here
output:
ESP8266 mode is: 1
The module MAC address is: 1A-FE-34-A0-7A-FC
Config done, IP is 192.168.0.186
test270515.lua:19: method not supported
The 19th line:
Code: Select allm:on("It works", function(conn, topic, data)
By Cobozco
#18768 The dream initially was to have an OpenHAB app publish a 0 or 1 to the NodeMCU which would later send a HI or LO depending to a GPIO pin for other circuitry...
Code: Select all-- connecting to R.PI(broker)
--Test over wifi with MQTT & LUA scripting
broker = "192.168.0.112"     -- IP or hostname of MQTT broker
mqttport = 1883          -- MQTT port (default 1883)
userID = ""              -- username for authentication if required
userPWD  = ""            -- user password if needed for security
clientID = "/light"        -- Device ID
ledPin = 4                -- IO Index of GPIO2 which is connected to an LED
count = 0                -- Test number of mqtt_do cycles
mqtt_state = 0           -- State control
WiFiUserID = "Bakery229"
WiFiPWD = "electronics229"
RoomID = "1"
gpio.mode(ledPin, gpio.OUTPUT)
gpio.write(ledPin, gpio.HIGH)
wifi.sta.config(WiFiUserID,WiFiPWD)
wifi.sta.connect()
tmr.alarm(1, 1000, 1, function()
  if wifi.sta.getip()== nil then
  print("IP unavaiable, Waiting...")
  tmr.stop(1)
 end)
m = mqtt.Client("ESP8266".. clientID, 180)
m:lwt("/lwt", "ESP8266", 0, 0)
    print ("Mqtt Reconnecting...")
      m:connect(broker, 1883, 0, function(conn)
        print("Mqtt Connected to:" .. broker)
        mqtt_sub() --run the subscription function
      end)
    end)
 end)
    print("Recieved:" .. topic .. ":" .. data)
      if (data=="0") then
      print("LED OFF")
      gpio.write(ledPin,gpio.LOW)
      m:publish("/light","ON",0,0)
    elseif (data=="1") then
      print("LED ON")
      gpio.write(ledPin,gpio.HIGH)
      m:publish("light","OFF",0,0)
      print("Invalid - Ignoring")
 end)
 function mqtt_sub()
    m:subscribe("/light",0, function(conn)
      print("Mqtt Subscribed to OpenHAB feed for device " .. clientID)
    end)
  if wifi.sta.status() == 5 and wifi.sta.getip() ~= nil then
    tmr.stop(0)
    end)
The result of this was output of the node heap (bunch of numbers) and it "reconnecting"
