By HermannSW
#20163 I did install latest nodemcu firmware yesterday.
In NodeMCU I try to excecute the command from wifi.ap.setip() doc
http://www.nodemcu.com/docs/wifi-ap-module/#wifi-ap-module-wifi-ap-setip
but it fails:
Code: Select all> cfg =
    "ip":"192.168.1.1",
    "netmask":"255.255.255.0",
    "gateway":"192.168.1.1"
  }>> stdin:3: '}' expected (to close '{' at line 2) near ':'
stdin:1: unexpected symbol near '}'
> tst={"a":"b"}
stdin:1: '}' expected near ':'
Is the documentation wrong, or does latest firmware have a bug?
Is there any workaround to set the AP ip address?
(it is 192.168.4.1 currently)
My ESP8266-01 mode is 3 (STA+AP), and I telnet into NodeMCU Telnet server over WiFi:
Hermann.
By HermannSW
#20202 Thank you, changing AP IP address worked!
Did I get the wrong NodeMCU API description (JavaScript instead of Lua)?
Or is the sample under this link plain wrong?
Code: Select allcfg={
  ip="192.168.179.1",
  netmask="255.255.255.0",
  gateway="192.168.179.1"
wifi.ap.setip(cfg)
Hermann.
