can someone help me to optimize this code? I'm getting the "Not enough Memory" error
BOARD_NAME = "minitron"
-- wifi connection
IPADR = "192.168.1.112" --Requested static IP address for the ESP
IPROUTER = "192.168.1.1" --IP address for the Wifi router
wifi.setmode(wifi.STATION)
wifi.sta.autoconnect(1)
wifi.sta.setip({ip=IPADR,netmask="255.255.255.0",gateway=IPROUTER})
wifi.sta.config("SSID","PASSWORD")
print(wifi.sta.getip())
led1 = 3
led2 = 4
gpio.mode(led1, gpio.OUTPUT)
gpio.mode(led2, gpio.OUTPUT)
-- entrambi off all'avvio
gpio.write(led1, gpio.LOW)
gpio.write(led2, gpio.LOW)
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive", function(client,request)
local buf = "";
local method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
method, path = string.find(request, "([A-Z]+) (.+) HTTP");
local _GET = {}
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
_GET[k] = v
if (_GET.ping=="board")then
client:send("{\"key\": true, \"nome_board\":\""..BOARD_NAME.."\", \"chip_id\":"..node.chipid()..", \"ip_address\": \""..wifi.sta.getip().."\"}")
elseif(_GET.toggle=="1") then
new_s = (gpio.read(led1)==1 and gpio.LOW or gpio.HIGH)
gpio.write(led1, new_s);
current_status = (new_s==gpio.LOW and 0 or 1);
client:send("{\"pin\":1, \"new_state\":"..current_status.."}")
elseif(__GET.toggle=="2") then
new_s = (gpio.read(led2)==1 and gpio.LOW or gpio.HIGH)
gpio.write(led2, new_s);
client:send("{\"pin\":2, \"new_state\":"..current_status.."}")
elseif (_GET.get=="1") then
client:send("{\"gpio_number\": 1, \"state\":"..gpio.read(led1).."}");
elseif(_GET.get=="2") then
client:send("{\"gpio_number\": 2, \"state\":"..gpio.read(led2).."}");
elseif(_GET.pin == "on1")then
gpio.write(led1, gpio.HIGH);
client:send("{\"gpio_number\": 1, \"state\":1}");
elseif(_GET.pin == "off1")then
gpio.write(led1, gpio.LOW);
client:send("{\"gpio_number\": 1, \"state\":0}");
elseif(_GET.pin == "on2")then
gpio.write(led2, gpio.HIGH);
client:send("{\"gpio_number\": 2, \"state\":1}");
elseif(_GET.pin == "off2")then
gpio.write(led2, gpio.LOW);
client:send("{\"gpio_number\": 2, \"state\":0}");
buf = buf.."<h1>ESP8266 Web Server</h1>";
buf = buf.."<p>GPIO0 <a href=\"?pin=on1\"><button>ON</button></a> <a href=\"?pin=off1\"><button>OFF</button></a> - "..gpio.read(led1).."</p>";
buf = buf.."<p>GPIO2 <a href=\"?pin=on2\"><button>ON</button></a> <a href=\"?pin=off2\"><button>OFF</button></a> - "..gpio.read(led2).."</p>";
client:send(buf);
client:close();
collectgarbage();
end)
end)
I have the latest NodeMCU custom firmware.
