s=net.createServer(net.TCP)
s:listen(80,function(c)
c:on("receive",function(c,pl)
for v,i in pairs{2,8,9} do
gpio.mode(i,gpio.OUTPUT)
c:send("\ngpio("..i.."):"..gpio.read(i))
if string.find(pl,"gpio"..i.."=0") then gpio.write(i,0) end
if string.find(pl,"gpio"..i.."=1") then gpio.write(i,1) end
c:send("\nnew_gpio("..i.."):"..gpio.read(i))
c:send("\nTMR:"..tmr.now().." MEM:"..node.heap())
c:on("sent",function(c) c:close() end)
end)
end)
end)
end)
If you look where it says:
gpio.mode(i,gpio.OUTPUT)For each step in that code, i gets an index which is specified I believe as (2,8,9)
And then set as an output .
In order to use GPIO we must first set it as an output or an input. So in this case only GPIO (2,8,9) is being used I believe.
I am not 100% sure on this as I am new but this is how I interpret the code so if you needed to use other GPIO's they would indeed have to be specified.
So if you wanted to use all GPIO's you would need to specify this in your index by adding the remaining GPIO's...
The next portion of the code----->
c:send("\ngpio("..i.."):"..gpio.read(i))Sends a string like so \ngpio7:0 if it is off or \ngpio7:1 if it were off or it will read and send the status of gpio's within the index and display or send the information in this manner.
The next line of code--->
if string.find(pl,"gpio"..i.."=0") then gpio.write(i,0) endWill check the string of data payload, for gpio and is in the index and a value of 0 then it will write to that index using gpio write the value of 0 or in english it will turn off.
The next line of code---->
if string.find(pl,"gpio"..i.."=1") then gpio.write(i,1) end Will check the string of data payload, for gpio and is in the index and a value of 1 then it will write to that index using gpio write the value of 1 or in english it will turn on.
The next line of code----->
c:send("\nnew_gpio("..i.."):"..gpio.read(i))Will send the new value of the GPIO like so \nnew_gpio7:0 if off or \nnew_gpio7:1 if on
(Keep in mind I am only using 7 as an example)
c:send("\nTMR:"..tmr.now().." MEM:"..node.heap()) c:on("sent",function(c) c:close() end) I am in the same boat with you on trying to understand stuff but little by little I am starting to understand it.
BTW this is an excellent bit of code who ever wrote it a very powerful yet compact code to use as a handler I thank who ever wrote it!!!
This code is not good however if you are just trying to push a button and turn stuff off and on you are better off using the buff:buff to create an HTML page that allows you to use a simple on or off button.
If anything here posted is wrong please correct me I am attempting to help with a somewhat limited knowledge of what I am doing.
Wishing for the best here.
Where I buy my ESP8266 boards from... (Banggood)
