By GeoNomad
#4676
Code: Select all-- choose the strongest open AP available and connect to it
-- tested with NodeMcu 0.9.2 build 20141212
ConnStatus = nil
function ConnStatus(n)
status = wifi.sta.status()
uart.write(0,' '..status)
local x = n+1
if (x < 50) and ( status < 5 ) then
   tmr.alarm(0,100,0,function() ConnStatus(x) end)
   if status == 5 then
   print('\nConnected as '..wifi.sta.getip())
   print("\nConnection failed")
best_ssid = nil
function best_ssid(ap_db)
local min = 100
for k,v in pairs(ap_db) do
    if tonumber(v) < min then
       min = tonumber(v)
       ssid = k
best = nil
function best(aplist)
ssid = nil
print("\nAvailable Open Access Points:\n")
for k,v in pairs(aplist) do print(k..' '..v) end
ap_db = nil
ap_db = {}
if nil ~= next(aplist) then
      if '0' == string.sub(v,1,1) then
         ap_db[k] = string.match(v, '-(%d+),')
   if nil ~= next(ap_db) then
      best_ssid(ap_db)
if nil ~= ssid then
   print("\nBest SSID: ".. ssid)
   wifi.sta.config(ssid,"")
   print("\nConnecting to "..ssid)
   ConnStatus(0)
   print("\nNo available open APs")
wifi.setmode(wifi.STATION)
wifi.sta.getap(function(t) best(t)  end)
Being a total newb to this Lua thing, some feedback on my use of tables and substrings would be useful.
This would use less heap without the function definitions, but would be much less easily readable.
