- Sat Mar 05, 2016 2:57 pm
#42499
Hi devsaurus,
Ok,
Modul: NodeMCU 1.0 (the black one) .. Flash Size : 4MB
Firmware: the original NodeMCU-Firmware (git clone
https://github.com/nodemcu/nodemcu-firmware.git)
with the following Modules: (user_modules.h)
Code: Select all//#define LUA_USE_MODULES_ADC
//#define LUA_USE_MODULES_BIT
//#define LUA_USE_MODULES_BMP085
//#define LUA_USE_MODULES_CJSON
//#define LUA_USE_MODULES_COAP
//#define LUA_USE_MODULES_CRYPTO
#define LUA_USE_MODULES_DHT
//#define LUA_USE_MODULES_ENDUSER_SETUP // USE_DNS in dhcpserver.h needs to be enabled for this module to work.
#define LUA_USE_MODULES_FILE
#define LUA_USE_MODULES_GPIO
//#define LUA_USE_MODULES_HX711
#define LUA_USE_MODULES_I2C
//#define LUA_USE_MODULES_MQTT
#define LUA_USE_MODULES_NET
#define LUA_USE_MODULES_NODE
#define LUA_USE_MODULES_OW
//#define LUA_USE_MODULES_PWM
//#define LUA_USE_MODULES_RC
//#define LUA_USE_MODULES_RTCFIFO
//#define LUA_USE_MODULES_RTCMEM
//#define LUA_USE_MODULES_RTCTIME
//#define LUA_USE_MODULES_SNTP
#define LUA_USE_MODULES_SPI
#define LUA_USE_MODULES_TMR
//#define LUA_USE_MODULES_TSL2561
//#define LUA_USE_MODULES_U8G
#define LUA_USE_MODULES_UART
#define LUA_USE_MODULES_UCG
#define LUA_USE_MODULES_WIFI
//#define LUA_USE_MODULES_WS2801
//#define LUA_USE_MODULES_WS2812 and additional the following fonts: (ucg_config.h)
Code: Select all#define UCG_FONT_TABLE \
UCG_FONT_TABLE_ENTRY(font_7x13B_tf) \
UCG_FONT_TABLE_ENTRY(font_fub42_hf) \
UCG_FONT_TABLE_ENTRY(font_fub30_hf) \
UCG_FONT_TABLE_ENTRY(font_helvB08_hf) \
UCG_FONT_TABLE_ENTRY(font_helvB10_hf) \
UCG_FONT_TABLE_ENTRY(font_helvB12_hf) \
UCG_FONT_TABLE_ENTRY(font_helvB18_hf) \
UCG_FONT_TABLE_ENTRY(font_ncenB24_hf) \
UCG_FONT_TABLE_ENTRY(font_ncenR12_hf) \
UCG_FONT_TABLE_ENTRY(font_ncenR14_hf)
#undef UCG_FONT_TABLE_ENTRY the files where compiled to .lua
Error messag, i use the ESPlorer: "none"
and the last point you post: didn't know what you mean ?
i think the problem could be the "clear.screen()" function..
if i don't switch the pages (i have three) than it works ok,
but when i trigger a page refresh (with the button) in 80%
of the time, the system crashes... without an error.. sometimes
only the Display hangs.. sometimes the whole Node reboots..
Next thing, that's not ok: i can't interact with NodeMCU if
the code is running.. e.g "node.restart()" or "node.heap()"
wont work.. i have to reboot with the button on the Node himself.
if i send "node.restart()" i get an timeout... so, perhaps i have
a loop in my code ? so the Node will not response to any commands..
but i can't find it..
Cheers Brick
