2. Load program srv41.lua to ESP with Lualoader
3. HW reset module
4. Login module to your AP - wifi.setmode(wifi.STATION),wifi.sta.config("yourSSID","yourPASSWORD")
5. Test IP address - wifi.sta.getip()
6. Run program srv41.lua - dofile(srv41.lua)
7. Test it with your browser.
I do not know why, but this server does not work with the latest version NodeMcu 0.9.3 build 20141222.
--wifi.setmode(wifi.STATION)
--wifi.sta.config("yourSSID","yourPassword")
outpin=4 -- Select right IO index !! Here is settings for GPIO2 (Lua build 20141219)
srv=net.createServer(net.TCP) srv:listen(80,function(conn)
--next row is for debugging output only
print(payload)
function ctrlpower()
pwm.close(outpin)
gpio.mode(outpin,gpio.OUTPUT)
dotaz=string.sub(payload,kdesi[2]+1,#payload)
if dotaz=="ON" then gpio.write(outpin,gpio.HIGH)return end
if dotaz=="OFF" then gpio.write(outpin,gpio.LOW)return end
if dotaz=="FLC" then pwm.setup(outpin,2,512)pwm.start(outpin)return end
pwm.setup(outpin,1000,dotaz*10)
pwm.start(outpin)
--parse position POST value from header
kdesi={string.find(payload,"pwmi=")}
--If POST value exist, set LED power
if kdesi[2]~=nil then ctrlpower()end
conn:send('HTTP/1.1 200 OK\n\n')
conn:send('<!DOCTYPE HTML>\n')
conn:send('<html>\n')
conn:send('<head><meta content="text/html; charset=utf-8">\n')
conn:send('<title>ESP8266</title></head>\n')
conn:send('<body><h1>Sample GPIO output control</h1>\n')
conn:send('<h3>For Lua NodeMcu 0.9.2 build 20141219 only !!!</h3>\n')
conn:send('<h3>Tested with IE 11. and Chrome 39.</h3>\n')
conn:send('<IMG SRC="http://esp8266.fancon.cz/common/led.gif" WIDTH="150" HEIGHT="101" BORDER="1"><br><br>\n')
conn:send('<form action="" method="POST">\n')
conn:send('<input type="submit" name="pwmi" value="OFF">\n')
conn:send('<input type="submit" name="pwmi" value="10">\n')
conn:send('<input type="submit" name="pwmi" value="20">\n')
conn:send('<input type="submit" name="pwmi" value="30">\n')
conn:send('<input type="submit" name="pwmi" value="40">\n')
conn:send('<input type="submit" name="pwmi" value="50">\n')
conn:send('<input type="submit" name="pwmi" value="60">\n')
conn:send('<input type="submit" name="pwmi" value="70">\n')
conn:send('<input type="submit" name="pwmi" value="80">\n')
conn:send('<input type="submit" name="pwmi" value="90">\n')
conn:send('<input type="submit" name="pwmi" value="ON"> % of power<br><br>\n')
conn:send('<input type="submit" name="pwmi" value="FLC"> HW blinker</form>\n')
conn:send('</body></html>\n')
end)
end)
