Page 1 of 8
Simple wifi web server for GPIO output control.
PostPosted: Mon Dec 22, 2014 2:01 pm
by jankop
1. Flash NodeMcu 0.9.2 build 20141219 to ESP module.
2. Load program srv41.lua to ESP with Lualoader
3. HW reset module
4. Login module to your AP - wifi.setmode(wifi.STATION),wifi.sta.config("yourSSID","yourPASSWORD")
5. Test IP address - wifi.sta.getip()
6. Run program srv41.lua - dofile(srv41.lua)
7. Test it with your browser.
I do not know why, but this server does not work with the latest version NodeMcu 0.9.3 build 20141222.
Code: Select all    --wifi.setmode(wifi.STATION)
    --wifi.sta.config("yourSSID","yourPassword")
    outpin=4 -- Select right IO index !! Here is settings for GPIO2 (Lua build 20141219)
    srv=net.createServer(net.TCP) srv:listen(80,function(conn)
    conn:on("receive",function(conn,payload)
    --next row is for debugging output only
    print(payload)
    function ctrlpower()
    pwm.close(outpin)
    gpio.mode(outpin,gpio.OUTPUT)
    dotaz=string.sub(payload,kdesi[2]+1,#payload)
    if dotaz=="ON"  then gpio.write(outpin,gpio.HIGH)return end
    if dotaz=="OFF" then gpio.write(outpin,gpio.LOW)return end
    if dotaz=="FLC" then pwm.setup(outpin,2,512)pwm.start(outpin)return end
    pwm.setup(outpin,1000,dotaz*10)
    pwm.start(outpin)
    end
    --parse position POST value from header
    kdesi={string.find(payload,"pwmi=")}
    --If POST value exist, set LED power
    if kdesi[2]~=nil then ctrlpower()end
    conn:send('HTTP/1.1 200 OK\n\n')
    conn:send('<!DOCTYPE HTML>\n')
    conn:send('<html>\n')
    conn:send('<head><meta  content="text/html; charset=utf-8">\n')
    conn:send('<title>ESP8266</title></head>\n')
    conn:send('<body><h1>Sample GPIO output control</h1>\n')
    conn:send('<h3>For Lua NodeMcu 0.9.2 build 20141219 only !!!</h3>\n')
   conn:send('<h3>Tested with IE 11. and Chrome 39.</h3>\n')
    conn:send('<IMG SRC="http://esp8266.fancon.cz/common/led.gif" WIDTH="150" HEIGHT="101" BORDER="1"><br><br>\n')
    conn:send('<form action="" method="POST">\n')
    conn:send('<input type="submit" name="pwmi" value="OFF">\n')
    conn:send('<input type="submit" name="pwmi" value="10">\n')
    conn:send('<input type="submit" name="pwmi" value="20">\n')
    conn:send('<input type="submit" name="pwmi" value="30">\n')
    conn:send('<input type="submit" name="pwmi" value="40">\n')
    conn:send('<input type="submit" name="pwmi" value="50">\n')
    conn:send('<input type="submit" name="pwmi" value="60">\n')
    conn:send('<input type="submit" name="pwmi" value="70">\n')
    conn:send('<input type="submit" name="pwmi" value="80">\n')
    conn:send('<input type="submit" name="pwmi" value="90">\n')
    conn:send('<input type="submit" name="pwmi" value="ON"> % of power<br><br>\n')
    conn:send('<input type="submit" name="pwmi" value="FLC"> HW blinker</form>\n')
    conn:send('</body></html>\n')
    conn:on("sent",function(conn) conn:close() end)
    end)
end)
Re: Simple wifi web server for GPIO output control.
PostPosted: Mon Dec 22, 2014 3:20 pm
by Erni
Thanks for sharing, that is very nice.
Very elegant solution to finding the POST value, and external picture.
PostPosted: Tue Dec 30, 2014 2:28 am
by ardhuru
This works wonderfully well from my desktop (IE, Firefox), but doesnt seem to work from an Android.
I tried a number of browsers on the Android (connected to the same router), and they all show the web page served by the ESP8266, but they all fail to control the module.
Is it to do with the browser(s) on Android? And if so, does ayone know a browser that does work?
PostPosted: Tue Dec 30, 2014 10:31 am
by picpic020960
Fine with Android 442 and native navigator
(polaroid phablet)
