Because I am too stupid to set up the compiler and ide (best would be with eclipse), make them accessible through LUA calls please
Explore... Chat... Share...
function fromJson(MSG)
local hashMap = {}
for k,v in string.gmatch(MSG,'"(%w+)":"(%w+)",') do
hashMap[k] = v;
for k,v in string.gmatch(MSG,'"(%w+)":"(%w+)"}') do
hashMap[k] = v;
return hashMap
function toJson(MAP)
local outMsg = "{"
for k,v in pairs(MAP) do
outMsg = outMsg..'"'..k..'":"'..v..'",'
return string.sub(outMsg,0,-2)..'}'
