Left for archival purposes.
By ucy74
#3547 As esp8266 works with SPI Winbond W25Q40BVNIG memory it wil be nice to get controll over SPI in general.
Both - software configured "virtual" and build-in hardware.
It will be good approach to work with SD-card.
Bootloader suports to treat MTDO (GPIO15) pin as selector to boot from (and work with) SD-card.
Then GPIO0 and GPIO2 work as SDIO interface.
Below is an image showing expanded GPIO12,13,14,15 pins - for software SPI...
By zeroday
#3814
ucy74 wrote:As esp8266 works with SPI Winbond W25Q40BVNIG memory it wil be nice to get controll over SPI in general.
use the spi master same as the one communicate with W25Q40, is almost impossible I think.
because, the code in the W25Q40 runs in XIP mode.
if the SDK get the spi slave/master driver work, it's easy to wrap in lua.
for the data log, maybe use the power of wifi/network/cloud?
By zarin
#3827
yes, but:
1. We can log data when network/cloud does not work. And transmit stored data to the cloud when network/cloud became reachable.
2. We can make "power-save" mode, when for example data from sensors is recorded every 1 minute and is transmitted to the cloud only every 10 minutes.
Networks and clouds can't be 100% reliable and work all the time. Sh*t can happen (= So it's good to be able to store data in some cases.
