brig wrote:Under the same conditions and with the same module, the program LuaUploader is working properly.
I flashed the firmware module nodemcu_512k.bin 12/12/2014 using ESP8266Flaysher. When you start LuaLoader this message appears, and then closes LuaLoader (but still present in RAM - you can see in Task Manager). I have Windows 7 64-bit. Previous releases LuaLoader (up to 2014.12.12) worked fine.
So what happens when first launched the LuaLoader, and then turn on the power module.
Are you saying this occurs when you run LuaLoader without using any menus or clicking any buttons? I am also on W7 64 bit.
LuaLoader doesn't require any extra files or automatically load any until you click load, so I am not sure where this error could come from. Make sure you have the latest LuaLoader and if you can give me more information, please tell me.
LuaLoader does save a log file, so if you have the log file in a write protected folder, maybe something like that could occur. I will look at that.
Are you running as administrator?
