I try to create a simple library but it did'nt work with more than 1 function.
Here is the code of the lib:
local demo_mod = {}
function demo_mod.Mult(a, b)
return a * b
function demo_mod.Add(a, b)
return a + b
return demo_modAnd here the testcode for using the lib:
demo = require "testlib"
local result1 = demo.Mult(10, 2)
local result2 = demo.Add(10, 2)
print(result1)
print(result2)The result of executing is:
testlibtest.lua:3: attempt to call field 'Add' (a nil value)
stack traceback:
testlibtest.lua:3: in main chunk
[C]: in function 'dofile'
stdin:1: in main chunk
If I test it with only the first function "Mult", everything's fine!
I have no idea, what the problem is.
Any suggestions?
Regards
Erik
