IDE
NEW - Runtime Lua syntax checker
Hi Guys,
It is my IDE for ESP8266. Written by me - for my needs as ESP entusiast.
It combines the essential tools, which a developer needs to use ESP8266 with NodeMCU (Lua) and MicroPython.
Main features:
-automatically detect firmware (MicroPython or NodeMCU)
-runtime LUA syntax check (new!)
-code highlight (lua, html, javascript, python, c),
-code completion proposal for Lua (not all libraries are included yet, but I'll)
-bookmarks
-remember last files and bookmarks
-built in help (included all help files from github)
-examples
-upload and download ESP file(s), compile, remove, view etc.
-flash new firmware using ESPFlasher(bow). (the folder "builds" contains two of my custom builds)
-drag and drop files, fast commands (at the bottom of the screen)
-automatically check for updates
etc.
TODO
It will be great if you share your MicroPython and Lua examples. I'm collecting examples, which I'll add to the next release of ESPCut.
Version log
v0.75 / 2016-11-21
- Added Lua JIT compiler
- Runtime check Lua code for syntax errors, and underline errors in editor
- Show error hint, when the mouse is over wrong code
- Added [Build] tab in the bottom panel
- Added action "Goto Line number (Ctrl+G)"
- Possibility to change color of the active line
- Added 2 firmware installations with different modules
- Fixed some errors in lua syntax file
v0.74 / 2016-11-05
- Improved editor
- Added Block Ident and BlockUnident functions
- Improved search and search/replace dialog
- Added bookmarks in editor popup menu
- Detect file changed outside of the application
- Fixed "Delete filr" problem
- Fixed problem Bookmark load
Download
http://espcut.com/
Hope it will usefull for you too.
