this is a simple q&d solution that enables me to send files over the network to my esp. It is supposed to be helpful in situations where one is testing code in a esp connected to the uart using maybe luauploader, and when he is happy with the results, he can then send them to another esp over the air.
The code that goes to the esp is the following:
m_upload.lua
upload=nill
upload=net.createServer(net.TCP,10)
upload:listen(88,function(c)
c:on("receive", function(c, fileName)
-- print(fileName)
if (fileName=="file_upload_start")then
c:send("**enter the file name**\n")
print("**file upload started**")
upload_mode=1
elseif (fileName=="file_upload_stop")then
file.close()
c:send("**file "..savedFile.." saved**\n")
c:send("heap :"..node.heap().."\n")
print("\n\r**file "..savedFile.." saved**")
print("heap :"..node.heap())
savedFile,fileName,upload_mode=nill,nill,nill
elseif (upload_mode==1)then
c:send("**opened file "..fileName.." for writing**\n")
print("**opened file "..fileName.." for writing**")
print("heap :"..node.heap().."\n")
savedFile=fileName
file.remove(fileName)
file.open(fileName, "w+")
upload_mode=2
elseif (upload_mode==2)then
c:send(">>"..fileName.."\n")
print(fileName.." >> " ..savedFile)
file.writeline(fileName)
end)
end)
--file.format()
--dofile("m_upload.lc")
--node.compile("m_upload.lua")
--print(node.heap())
--file.remove("init.lua")
you upload it to the esp, then call it by dofile("m_upload.lua") (or lc if you compile it) and it listens on port 88
for a connection from the pc
You can then use this script on linux (netcat is needed)
save it as an sh in the same folder as your lua scripts(chmode +x uploadtoesp.sh) and call it using the filename.lua and the ip of the remote esp as arguments, like so
uploadtoesp.sh test.lua 192.168.4.10
#!/bin/bash
echo -n file_upload_start | nc -w 1 $2 88
echo -n $1 | nc -w 1 $2 88
echo ""
#while read -r x; do sleep 0.2; echo "$x"; echo -n "$x" | nc -w 1 $2 88 ; done < $1
while read -r x; do sleep 0.2; echo -n $x | nc -w 1 $2 88 ; done < $1
echo ""
echo -n file_upload_stop | nc -w 2 $2 88
from windows use the following 2 files:
uploadtoesp.bat (again call it like uploadtoesp.bat XXX.lua X.X.X.X)
@echo off
echo | set /p dummyName="file_upload_start" | nc.exe -w 1 %2 88
echo | set /p dummyName="%1" | nc.exe -w 1 %2 88
echo.
nc.exe -e "parse.bat %1" %2 88
type %1
echo.
echo.
echo | set /p dummyName="file_upload_stop" | nc.exe -w 1 %2 88parse.bat
@echo off
set wait=50
echo wscript.sleep %wait% > wait.vbs
for /F "delims=" %%a in (%1) do ( echo | set /p dummyName=%%a
wscript.exe wait.vbs )
del wait.vbsyou will again neet to place them where you keep your lua script, or adjust the path.
you will also need nc for windows.
