Monday, February 13, 2017 12:07:30
Text upload: C:\Users\User\Dropbox\Programming\ESP8266\LUALoader\version 0.91\init.lua
9805 bytes uploaded to init.lua
> = node.heap()
43280
> node.restart()
> ü!ÿ¤„ÿ1ä)Mô1ä)=ÜŽÿ‚,>þþ
Communications Error - Check baud rate
€)!J„¶D”Œ19Å
M¥0nÅ!Fÿ·ëÕ½{u{wýÉÑ¡)
dofile(init.lua) Monday, February 13, 2017 12:16:08
dofile("init.lua")
E:M 2056
not enough memory
stack traceback:
[C]: in function 'dofile'
stdin:1: in main chunk
Everyone,
I have the Wemos D1MiniPro at 16MB of memory. I have been trying to upload my script that is at 11,220 Bytes (12,288 on disk).
Anyone know why this is a limitation of the Wemos / ESP8266. I have tried multiple Chips and each one gives off this error. Thank you for your feedback. My assumtion is regardless of my Chip being handle to handle 16 Megabytes that it is perhaps the firmware that is only allocating X Amount?
I am using a firmware build from NodeMCU's cloud service.
--Shrink with https://mothereff.in/lua-minifier
--dofile 'includes.lua'
uart.setup(0, 9600, 8, 0, 1, 1)
print("Init Loading")
-- configure for 9600, 8N1, with echo
-- Add Host Mode
gpio0 =3
gpio2 =4
gpio.mode(gpio2,gpio.OUTPUT)
gpio.write(gpio2,gpio.LOW)
local GateWayIP = "192.168.2.1"
local UARTstatus = nil
local unescape = function (s)
s = string.gsub(s, "+", " ")
s = string.gsub(s, "%%(%x%x)", function (h)
return string.char(tonumber(h, 16))
end)
return s
function StartHostAP()
wifi.setmode(wifi.STATIONAP)
local cfg={}
local str=wifi.ap.getmac();
local ssidTemp=string.format("%s%s%s",string.sub(str,10,11),string.sub(str,13,14),string.sub(str,16,17));
cfg.ssid="ESP8266_"..ssidTemp;
cfg.pwd="12345678"
UARTstatus = "ESP8266_"..ssidTemp.."|PW: 12345678"
wifi.ap.config(cfg)
cfg={}
cfg.ip=GateWayIP;
cfg.netmask="255.255.255.0";
cfg.gateway=GateWayIP;
wifi.ap.setip(cfg);
StartDNS()
function StartDNS()
s=net.createServer(net.UDP)
s:on("receive",function(s,c)
transaction_id=string.sub(c,1,2)
flags=string.sub(c,3,4)
questions=string.sub(c,5,6)
query = ""
raw_query = ""
j=13
while true do
byte = string.sub(c,j,j)
j=j+1
raw_query = raw_query .. byte
if byte:byte(1)==0x00 then --NULL marks end of the string.
break
for i=1,byte:byte(1) do
j=j+1
query = query .. byte
query = query .. '.'
query=query:sub(1,query:len()-1) --strip the trailing dot.
q_type = string.sub(c,j,j+1)
j=j+2
if q_type == unhex("00 01") then
--print("Got a type A query "..query)
class = string.sub(c,j,j+1)
--ip = "192.168.2.1"
ip=unhex("C0 A8 02 01")
answers = unhex("00 01")
flags = unhex("81 80")
resp=transaction_id..flags..questions..answers..unhex("00 00")..unhex("00 00")..raw_query..q_type..class
resp=resp..unhex("c0 0c")..q_type..class..unhex("00 00 00 da")..unhex("00 04")..ip
s:send(resp)
end)
s:on("sent",function(s)
--s:close()
end)
s:listen(53)
print("listening, free:", node.heap())
prodconn = nil
prodsrv=net.createServer(net.TCP)
function ProdWebServer()
dofile 'ProdWebServer.lua'
prodsrv:listen(80,function(prodconn)
prodconn:on("receive", function(client,request)
local buf = "";
local buf2 = "";
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
local _GET = {}
buf = buf.."HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n";
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(.+)&*") do
--for k, v in string.gmatch(vars, "([%w+)=([%w%%]+)&*") do
_GET[k] = v
print("\r\nGot -" .. v)
elseif (vars == nil)then
buf = displayWebpage()
if(_GET.pin == "ON1")then
gpio.write(gpio0, gpio.HIGH);
elseif(_GET.pin == "OFF1")then
gpio.write(gpio0, gpio.LOW);
elseif(_GET.pin == "ON2")then
gpio.write(gpio2, gpio.HIGH);
elseif(_GET.pin == "OFF2")then
gpio.write(gpio2, gpio.LOW);
elseif(_GET.cmd == "resetwifi")then
file.remove("config.lc")
node.restart()
elseif(_GET.cmd == "reboot")then
node.restart()
elseif(_GET.cmdtx ~= nil)then
uart.write(0, _GET.cmdtx)
--print("Unescaped " .. unescape(_GET.cmdtx))
elseif(_GET.cmdtxcr ~= nil)then
uart.write(0, _GET.cmdtxcr.."\r")
--print("Unescaped " .. unescape(_GET.cmdtxcr).."\r")
client:send(buf);
client:close();
collectgarbage();
end)
end)
function Join()
print ("joining SSID")
print(wifi.sta.getip())
--nil
wifi.setmode(wifi.STATION)
wifi.sta.config(ssid, password)
wifi.sta.connect()
tmr.alarm(2, 1000, 1, function()
if wifi.sta.getip() == nil then
UARTstatus = "Connecting..."
tmr.stop(2)
UARTstatus = "Connected, IP IS|" .. wifi.sta.getip()
end)
ProdWebServer()
function StartConfigWebServer()
wifi.sta.getap(function(t)
available_aps = ""
if t then
for k,v in pairs(t) do
ap = string.format("%-10s",k)
ap = trim(ap)
available_aps = available_aps .. "<option value='".. ap .."'>".. ap .."</option>"
end)
print("Setting up webserver")
srv = nil
srv:listen(80,function(conn)
local buf = ""
local _GET = {}
for k, v in string.gmatch(vars, "(%w+)=([^%&]+)&*") do
_GET[k] = unescape(v)
if (_GET.ap ~= nil and _GET.ipTCP ~= nil) then --_GET.psw ~= nil The password can be NULL
client:send("Saving data..")
file.open("config.lua", "w")
file.writeline('ssid = "' .. _GET.ap .. '"')
if (_GET.HostAP ~= nil) then
file.writeline('HostAP = "true"')
file.writeline('HostAP = "false"')
if (_GET.psw ~= nil) then
file.writeline('password = "' .. _GET.psw .. '"')
file.writeline('password = ""')
file.writeline('ipTCP = "' .. _GET.ipTCP .. '"')
file.close()
node.compile("config.lua")
file.remove("config.lua")
client:send(buf)
node.restart()
buf = "<html><body>"
buf = buf .. "<h3>Config</h3><br>"
buf = buf .. "<form method='get' action='http://" .. wifi.ap.getip() .."'>"
buf = buf .. "Select access point: <select name='ap'>" .. available_aps .. "</select><br>"
buf = buf .. "Enter wifi password: <input type='password' name='psw'></input><br>"
buf = buf .. "Server-IP: <input name='ipTCP' value='192.168.2.1'></input><br>"
buf = buf .. "<input type='checkbox' name='HostAP' value='true'>Act as AP<br>"
buf = buf .. "<br><button type='submit'>Save</button>"
buf = buf .. "</form></body></html>"
client:send(buf)
client:close()
collectgarbage()
end)
UARTstatus = "Please connect to:|" .. wifi.ap.getip()
end)
function ConnStatus(n)
status = wifi.sta.status()
uart.write(0,' '..status)
local x = n+1
if (x < 50) and ( status < 5 ) then
tmr.alarm(3,100,0,function() ConnStatus(x) end)
if status == 5 then
print('\nConnected as '..wifi.sta.getip())
--dofile('relaywebserver.lua')
print("\nConnection failed")
function best_ssid(ap_db)
local min = 100
ssid = nil
for k,v in pairs(ap_db) do
if tonumber(v) < min then
min = tonumber(v)
ssid = k
--gpio.write(gpio2,gpio.LOW)
--gpio.write(gpio2,gpio.HIGH)
return min
function strongest(aplist)
print("\nAvailable Open Access Points:\n")
for k,v in pairs(aplist) do print(k..' '..v) end
ap_db = {}
if next(aplist) then
if '0' == string.sub(v,1,1) then
ap_db[k] = string.match(v, '-(%d+),')
signal = -best_ssid(ap_db)
if ssid then
print("\nBest SSID: ".. ssid)
wifi.sta.config(ssid,"")
print("\nConnecting to "..ssid)
ConnStatus(0)
print("\nNo available open APs")
ssid = ''
function unhex(str)
str = string.gsub (str, "(%x%x) ?",
function(h) return string.char(tonumber(h,16)) end)
return str
-- String trim left and right
function trim (s)
return (s:gsub ("^%s*(.-)%s*$", "%1"))
function hex_dump (str)
local len = string.len( str )
local dump = ""
local hex = ""
local asc = ""
for i = 1, len do
if 1 == i % 8 then
dump = dump .. hex .. asc .. "\n"
hex = string.format( "%04x: ", i - 1 )
asc = ""
local ord = string.byte( str, i )
hex = hex .. string.format( "%02x ", ord )
if ord >= 32 and ord <= 126 then
asc = asc .. string.char( ord )
asc = asc .. "."
return dump .. hex
.. string.rep( " ", 8 - len % 8 ) .. asc
-- when '\r' is received.
uart.on("data", "\r",
function(data)
data=trim (data)
print("receive from uart:", data)
print(hex_dump(data))
if data=="quit()" then
print("got quit")
uart.on("data")
elseif data=="scan()" then
print("Scanning")
UARTstatus = "scanning"
wifi.setmode(wifi.STATION) wifi.sta.getap(function(t) if t then print("\n\nVisible Access Points:\n") for k,v in pairs(t) do l = string.format("%-10s",k) print(l.." "..v) end else print("Try again") end end)
elseif data=="join()" then
Join()
elseif data=="strongest()" then
wifi.sta.getap(function(t) strongest(t) end)
elseif data=="resetwifi()" then
node.restart()
elseif data=="config()" then
StartHostAP()
elseif data=="dns()" then
StartDNS()
--uart.on("data")
end, 0)
if pcall(function () dofile("config.lc") end) then
if HostAP == "true" then
UARTstatus = "Loading|AccessPoint"
print (ssid.." "..password)
StartHostAP()
ProdWebServer()
UARTstatus = "Settings Found|"..ssid
Join()
UARTstatus = "Loading|AccessConfig"
StartHostAP()
tmr.alarm(0,30000,1,function() print("Stopping uART") uart.on("data") tmr.stop(0) end)
tmr.alarm(1,5000,1,function() print("!"..UARTstatus) end)
