I'm going to have a go at trying the various methods that have been suggested on here and also compiling from scratch.
I'll let you know how I get on and if I'm successful I'll post the steps on here (including the working bin files!)..
Explore... Chat... Share...
devsaurus wrote:This is missing the flash parameters for a 4 MByte module. Something like:Code: Select allsudo python esptool.py --port /dev/ttyUSB0 write_flash -fs 32m -fm dio 0x0000 nodemcu-master-22-modules-2016-08-10-16-54-08-float.bin 0x3fc000 esp_init_data_default.bin
Depending on the type of module '-fm qio' could also work.
ChrisSparks wrote:I was able to connect at 115200 well yeah!
I was able to run my first init.lua script (the one that setups up a connection to my router) and it was happy!
Thanks for the help.
