file.remove('config.lc') does not help.
Re-Flashing the .bin file also does not help.
what ever I do , it just logs on to the Router.
Explore... Chat... Share...
esptool.py --port <serial-port-of-ESP8266> erase_flash
wifi.sta.config("xxxxxxxx","xxxxxxxx"wifi.sta.config(string.char(0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff),string.char(0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff)) It takes about 20-25 seconds for home assistant c[…]
