74880 Baud shows the following...
load 0x40100000, len 25576, room 16
tail 8
chksum 0x1f
load 0x3ffe8000, len 2184, room 0
tail 8
chksum 0x0f
load 0x3ffe8888, len 8, room 0
tail 8
chksum 0xa4
csum 0xa4
rf_cal[0] !=0x05,is 0x00However I can flash an earlier binary: nodemcu_float_0.9.6-dev_20150704.bin which I found floating around on the web somewhere, and it works just fine. Here is the successful command...
esptool.py --port /dev/ttyUSB0 write_flash 0x00000 nodemcu_float_0.9.6-dev_20150704.binI can also flash v1111ATFirmware.bin successfully using...
esptool.py --port /dev/ttyUSB2 write_flash --flash_mode dio --flash_size 32m 0x0 v1111ATFirmware.bin
Any ideas on what I do next to figure out how to flash the newer nodemcu binary correctly? The older one doesn't have tmr.create(), which I'm going to need. Thanks.
