Below are some major bits of Lua code used.
orgID = "quickstart" -- IoT Foundation organization ID
broker = "test.mosquitto.org" --orgID..".messaging.internetofthings.ibmcloud.com" -- IP or hostname of IoTF service
mqttPort = 1883 -- MQTT port (default 1883: non-secure)
userID = "" -- blank for quickstart
userPWD = "" -- blank for quickstart
macID = "18fe34e1b007" -- unique Device ID or Ethernet Mac Address <==== Modify this!
clientID = ":esp8266:18fe34e1b007" -- Client ID
count = 0 -- Test number of mqtt_do cycles
mqttState = 0 -- State control
topic = "topic/temp/motion"
led = 4
--gpio.mode(led,gpio.OUTPUT)
--dht sensor settings------------------------------
pin = 1
-- PIR initialization section
pir = 2
x= 0 -- variable for sending motion detection information in "0 or 1"
function DHT_do()
status, temp, humi, temp_dec, humi_dec = dht.read(pin)
--gpio.write(led, gpio.LOW)
function mqtt_do()
count = count + 1 -- tmr.alarm counter
------------------------------------------- pir conditional code
if gpio.read(pir) ~= last_state then
last_state = gpio.read(pir)
if last_state == 1 then
print("ON")
x = 1
gpio.write(led,gpio.HIGH)
print("OFF")
x = 0
gpio.write(led,gpio.LOW) m:publish(topic,x, 0, 0,
function(conn)
print(x)
print("temp_data:"..temp)
