Background: I had been successfully using the HTTP module to place requests over my LAN to a LED Lighting Hub (that's had its cloud service discontinued!) but after adding a few more bulbs my code started failing when placing a discovery request. I determined that this was due to the response payload exceeding around 5Kbytes and hence running out of RAM.
Taking the advice in the docs:
If larger page/body sizes are necessary, consider using net.createConnection() and stream in the dataSo I re-wrote the request accordingly but It hasn't helped. While all requests that result in short responses succeed as before, the discovery request just returns the reply header (showing Content-Length >~5K) but then disconnects imediately. Sucessful requests return the reply header and the payload in successive callbacks - then disconnect after a few seconds timeout from the Lighting Hub.
Here's the function that performs the request (two example php?cmd are shown in skt:send, the first simple one that's commented out is to turn on a lamp. The second one performs the device discovery that fails to return the payload)
function sendRequest()
skt = net.createConnection(net.TCP, 1) --SSL=1
skt:on("connection", function(skt)
print("connected to hub")
skt:send("GET /"
--"gwr/gop.php?cmd=DeviceSendCommand&data=<gip><version>1</version><token>5mcopjq4x2j5rv429pbbkp7tbvq0ubtpov4j5zs8</token><did>216771547807313123</did><value>0</value></gip>&fmt=xml"
.."gwr/gop.php?cmd=GWRBatch&data=<gwrcmds><gwrcmd><gcmd>RoomGetCarousel</gcmd><gdata><gip><version>1</version><token>5mcopjq4x2j5rv429pbbkp7tbvq0ubtpov4j5zs8</token><fields>name</fields></gip></gdata></gwrcmd></gwrcmds>&fmt=xml"
.." HTTP/1.1\r\nHost: 192.168.1.66\r\nConnection: keep-alive\r\nTransfer-Encoding: chunked\r\nAccept: */*\r\n\r\n"
end)
skt:on("reconnection", function(skt)
print("> reconnection")
end)
skt:on("disconnection", function(skt)
print("> disconnection")
skt:close()
end)
skt:on("sent", function(skt)
print("> sent")
end)
skt:on("receive", function(skt, payload)
print("> rx payload len:"..string.len(payload))
print(payload)
end)
skt:connect(443,"192.168.1.66")
endNote that I've tried using Connection: keep-alive and Transfer-Encoding: chunked in the requests.
First, the output from the succesful "Lamp on" request which triggers two "on receive" callbacks with payload lengths of 111 and 43:
> connected to hub
> sent
> rx payload len:111
HTTP/1.1 200 OK
Date: Tue, 15 Nov 2016 12:42:08 GMT
Server:
Content-Type: text/html
Content-Length: 43
> rx payload len:43
<gip><version>1</version><rc>200</rc></gip>
> disconnection
Then the output from the "Discovery" request which only triggers a callback for the 113 byte header, not the 5697 byte payload:
> connected to hub
> sent
> rx payload len:113
HTTP/1.1 200 OK
Date: Tue, 15 Nov 2016 12:42:57 GMT
Server:
Content-Length: 5697
> disconnection
If I remove a couple of bulbs it works but the whole ~5K payload comes back in one callback:
> connected to hub
> sent
> rx payload len:113
HTTP/1.1 200 OK
Date: Tue, 15 Nov 2016 13:29:10 GMT
Server:
Content-Length: 5033
> rx payload len:5033
<gwrcmds><gwrcmd><gcmd>RoomGetCarousel</gcmd> ... ~5K of discovery details here!
> disconnection
I thought there was a buffer size of 1460 and the callbacks would return up to this amount each time. This Post http://www.esp8266.com/viewtopic.php?f=24&t=3901 also seems to suggest that I should see that.
