Page 1 of 2
weird ascii characters on nodemcu serial
PostPosted: Thu Dec 01, 2016 3:51 pm
by francesco.u
Hi guys,
I've bought three yellow NodeMcu Dev Boards (VER 0.9, yellow), unfortunately none of them seems to work.
I've flashed the firmware several times (using the latest esptool.py), also with different settings.
Once the flash is completed, I remove the USB cable and then reconnect it.
The blue led starts to blink very very fast and when I try to open the serial port (with baud 115200) I get a bunch of weird characters, e.g.:
Code: Select allsd$��|�l�< �l�c|����;�clc��gn�dog���c8��lrl;lp�'� � l  co�<�d�s�ć#��og�l��l �g'l`orǛ�' ��d`8�g� r�����  b '�|�ld��b��og� $`�gn �los���n {��`p�g�s����� d �c n�| b��og� �$`�og�ln{���g ��ls��n � �d���8�on�$dld�#� ��`{ll��|�d�| � d� b<����s�cd #��ng�$gn���cp��d{$sd8�o� �$   b '�|�l�{���c��gn�dćd`�'o $`gs���o ��l`p�'� s�ܜ�� co�<�dl��c��go� l`�ng�$'{���g s�� x�n� {�����l�cg�| c��gn��l`�g
is there anything else I can try?
Thanks in advance
Re: weird ascii characters on nodemcu serial
PostPosted: Fri Dec 02, 2016 1:31 am
by marcelstoer
I assume you're familiar with http://nodemcu.readthedocs.io/en/latest ... #esptoolpy? Did you set the correct flash mode? Do you have an esptool.py version recent enough to include flash size auto detection? What firmware version do you use?
PostPosted: Fri Dec 02, 2016 9:44 am
by francesco.u
marcelstoer wrote:I assume you're familiar with http://nodemcu.readthedocs.io/en/latest ... #esptoolpy? Did you set the correct flash mode? Do you have an esptool.py version recent enough to include flash size auto detection? What firmware version do you use?
Hi, I've flashed the latest firmware (master, default configuration) built on https://nodemcu-build.com using the latest esptool.py
I've also tried different flash mode but nothing changes. I get no error after flashing but I can't use the device with ESPLoader
I've used the same setup with other (more recent...I guess) black NodeMCU boards and everything works out of the box. I guess that the yellow board has something different, here is the model I have: http://www.banggood.com/NodeMcu-Lua-WIF ... 76440.html
PostPosted: Sat Dec 03, 2016 8:43 am
by francesco.u
I think I've made some progress...flashing this way:
Code: Select allesptool.py --port /dev/ttyUSB0 write_flash -fm dio -fs 32m -ff 4m 0x00000 bin/nodemcu_integer_master_20161203-1334.bin  0x3FC000 ~/esp_init_data_default.bin
the blue led doesn't blink anymore and when I open the serial on ESPlorer I get (after 30 seconds!!!):
Code: Select allPlease, reset module or continue.
|s��o�b�� �n�c���p� l�l�|l�b��oo�lrll�bs| �|l b��p lr�bl`p��b �p�oon��n��|loo삞| o��`� �
=node.heap()
����c�
=node.heap()
=node.heap()
stdin:1: unexpected symbol near '�'
=node.heap()
=node.heap()
45528
there are some weird characters but it seems to work....until I click "close".
If I try to re-open it doesn't work anymore and I have to flash it again...
