not enough memory
Posted: Mon Feb 13, 2017 3:23 pm
Monday, February 13, 2017 12:07:30
Text upload: C:\Users\User\Dropbox\Programming\ESP8266\LUALoader\version 0.91\init.lua
9805 bytes uploaded to init.lua
> = node.heap()
43280
> node.restart()
> ü!ÿ¤„ÿ1ä)Mô1ä)=ÜŽÿ‚,>þþ
Communications Error - Check baud rate
€)!J„¶D”Œ19Å
M¥0nÅ!Fÿ·ëÕ½{u{wýÉÑ¡)
dofile(init.lua) Monday, February 13, 2017 12:16:08
dofile("init.lua")
E:M 2056
not enough memory
stack traceback:
[C]: in function 'dofile'
stdin:1: in main chunk
Everyone,
I have the Wemos D1MiniPro at 16MB of memory. I have been trying to upload my script that is at 11,220 Bytes (12,288 on disk).
Anyone know why this is a limitation of the Wemos / ESP8266. I have tried multiple Chips and each one gives off this error. Thank you for your feedback. My assumtion is regardless of my Chip being handle to handle 16 Megabytes that it is perhaps the firmware that is only allocating X Amount?
I am using a firmware build from NodeMCU's cloud service.
--Shrink with https://mothereff.in/lua-minifier
--dofile 'includes.lua'
uart.setup(0, 9600, 8, 0, 1, 1)
print("Init Loading")
-- configure for 9600, 8N1, with echo
-- Add Host Mode
gpio0 =3
gpio2 =4
gpio.mode(gpio2,gpio.OUTPUT)
gpio.write(gpio2,gpio.LOW)
local GateWayIP = "192.168.2.1"
local UARTstatus = nil
local unescape = function (s)
s = string.gsub(s, "+", " ")
s = string.gsub(s, "%%(%x%x)", function (h)
return string.char(tonumber(h, 16))
end)
return s
end
function StartHostAP()
wifi.setmode(wifi.STATIONAP)
local cfg={}
local str=wifi.ap.getmac();
local ssidTemp=string.format("%s%s%s",string.sub(str,10,11),string.sub(str,13,14),string.sub(str,16,17));
cfg.ssid="ESP8266_"..ssidTemp;
cfg.pwd="12345678"
UARTstatus = "ESP8266_"..ssidTemp.."|PW: 12345678"
wifi.ap.config(cfg)
cfg={}
cfg.ip=GateWayIP;
cfg.netmask="255.255.255.0";
cfg.gateway=GateWayIP;
wifi.ap.setip(cfg);
StartDNS()
end
function StartDNS()
s=net.createServer(net.UDP)
s:on("receive",function(s,c)
transaction_id=string.sub(c,1,2)
flags=string.sub(c,3,4)
questions=string.sub(c,5,6)
query = ""
raw_query = ""
j=13
while true do
byte = string.sub(c,j,j)
j=j+1
raw_query = raw_query .. byte
if byte:byte(1)==0x00 then --NULL marks end of the string.
break
end
for i=1,byte:byte(1) do
j=j+1
query = query .. byte
end
query = query .. '.'
end
query=query:sub(1,query:len()-1) --strip the trailing dot.
q_type = string.sub(c,j,j+1)
j=j+2
if q_type == unhex("00 01") then
--print("Got a type A query "..query)
class = string.sub(c,j,j+1)
--ip = "192.168.2.1"
ip=unhex("C0 A8 02 01")
answers = unhex("00 01")
flags = unhex("81 80")
resp=transaction_id..flags..questions..answers..unhex("00 00")..unhex("00 00")..raw_query..q_type..class
resp=resp..unhex("c0 0c")..q_type..class..unhex("00 00 00 da")..unhex("00 04")..ip
s:send(resp)
end
end)
s:on("sent",function(s)
--s:close()
end)
s:listen(53)
print("listening, free:", node.heap())
end
prodconn = nil
prodsrv=net.createServer(net.TCP)
function ProdWebServer()
dofile 'ProdWebServer.lua'
prodsrv:listen(80,function(prodconn)
prodconn:on("receive", function(client,request)
local buf = "";
local buf2 = "";
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
end
local _GET = {}
buf = buf.."HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n";
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(.+)&*") do
--for k, v in string.gmatch(vars, "([%w+)=([%w%%]+)&*") do
_GET[k] = v
print("\r\nGot -" .. v)
end
elseif (vars == nil)then
buf = displayWebpage()
end
if(_GET.pin == "ON1")then
gpio.write(gpio0, gpio.HIGH);
elseif(_GET.pin == "OFF1")then
gpio.write(gpio0, gpio.LOW);
elseif(_GET.pin == "ON2")then
gpio.write(gpio2, gpio.HIGH);
elseif(_GET.pin == "OFF2")then
gpio.write(gpio2, gpio.LOW);
elseif(_GET.cmd == "resetwifi")then
file.remove("config.lc")
node.restart()
elseif(_GET.cmd == "reboot")then
node.restart()
elseif(_GET.cmdtx ~= nil)then
uart.write(0, _GET.cmdtx)
--print("Unescaped " .. unescape(_GET.cmdtx))
elseif(_GET.cmdtxcr ~= nil)then
uart.write(0, _GET.cmdtxcr.."\r")
--print("Unescaped " .. unescape(_GET.cmdtxcr).."\r")
end
client:send(buf);
client:close();
collectgarbage();
end)
end)
end
function Join()
print ("joining SSID")
print(wifi.sta.getip())
--nil
wifi.setmode(wifi.STATION)
wifi.sta.config(ssid, password)
wifi.sta.connect()
tmr.alarm(2, 1000, 1, function()
if wifi.sta.getip() == nil then
UARTstatus = "Connecting..."
else
tmr.stop(2)
UARTstatus = "Connected, IP IS|" .. wifi.sta.getip()
end
end)
ProdWebServer()
end
function StartConfigWebServer()
wifi.sta.getap(function(t)
available_aps = ""
if t then
for k,v in pairs(t) do
ap = string.format("%-10s",k)
ap = trim(ap)
available_aps = available_aps .. "<option value='".. ap .."'>".. ap .."</option>"
end
end
end)
print("Setting up webserver")
srv = nil
srv:listen(80,function(conn)
local buf = ""
end
local _GET = {}
for k, v in string.gmatch(vars, "(%w+)=([^%&]+)&*") do
_GET[k] = unescape(v)
end
end
if (_GET.ap ~= nil and _GET.ipTCP ~= nil) then --_GET.psw ~= nil The password can be NULL
client:send("Saving data..")
file.open("config.lua", "w")
file.writeline('ssid = "' .. _GET.ap .. '"')
if (_GET.HostAP ~= nil) then
file.writeline('HostAP = "true"')
else
file.writeline('HostAP = "false"')
end
if (_GET.psw ~= nil) then
file.writeline('password = "' .. _GET.psw .. '"')
else
file.writeline('password = ""')
end
file.writeline('ipTCP = "' .. _GET.ipTCP .. '"')
file.close()
node.compile("config.lua")
file.remove("config.lua")
client:send(buf)
node.restart()
end
buf = "<html><body>"
buf = buf .. "<h3>Config</h3><br>"
buf = buf .. "<form method='get' action='http://" .. wifi.ap.getip() .."'>"
buf = buf .. "Select access point: <select name='ap'>" .. available_aps .. "</select><br>"
buf = buf .. "Enter wifi password: <input type='password' name='psw'></input><br>"
buf = buf .. "Server-IP: <input name='ipTCP' value='192.168.2.1'></input><br>"
buf = buf .. "<input type='checkbox' name='HostAP' value='true'>Act as AP<br>"
buf = buf .. "<br><button type='submit'>Save</button>"
buf = buf .. "</form></body></html>"
client:send(buf)
client:close()
collectgarbage()
end)
UARTstatus = "Please connect to:|" .. wifi.ap.getip()
end)
end
function ConnStatus(n)
status = wifi.sta.status()
uart.write(0,' '..status)
local x = n+1
if (x < 50) and ( status < 5 ) then
tmr.alarm(3,100,0,function() ConnStatus(x) end)
else
if status == 5 then
print('\nConnected as '..wifi.sta.getip())
--dofile('relaywebserver.lua')
else
print("\nConnection failed")
end
end
end
function best_ssid(ap_db)
local min = 100
ssid = nil
for k,v in pairs(ap_db) do
if tonumber(v) < min then
min = tonumber(v)
ssid = k
end
end
--gpio.write(gpio2,gpio.LOW)
--gpio.write(gpio2,gpio.HIGH)
return min
end
function strongest(aplist)
print("\nAvailable Open Access Points:\n")
for k,v in pairs(aplist) do print(k..' '..v) end
ap_db = {}
if next(aplist) then
if '0' == string.sub(v,1,1) then
ap_db[k] = string.match(v, '-(%d+),')
end
end
signal = -best_ssid(ap_db)
end
if ssid then
print("\nBest SSID: ".. ssid)
wifi.sta.config(ssid,"")
print("\nConnecting to "..ssid)
ConnStatus(0)
else
print("\nNo available open APs")
ssid = ''
end
end
function unhex(str)
str = string.gsub (str, "(%x%x) ?",
function(h) return string.char(tonumber(h,16)) end)
return str
end
-- String trim left and right
function trim (s)
return (s:gsub ("^%s*(.-)%s*$", "%1"))
end
function hex_dump (str)
local len = string.len( str )
local dump = ""
local hex = ""
local asc = ""
for i = 1, len do
if 1 == i % 8 then
dump = dump .. hex .. asc .. "\n"
hex = string.format( "%04x: ", i - 1 )
asc = ""
end
local ord = string.byte( str, i )
hex = hex .. string.format( "%02x ", ord )
if ord >= 32 and ord <= 126 then
asc = asc .. string.char( ord )
else
asc = asc .. "."
end
end
return dump .. hex
.. string.rep( " ", 8 - len % 8 ) .. asc
end
-- when '\r' is received.
uart.on("data", "\r",
function(data)
data=trim (data)
print("receive from uart:", data)
print(hex_dump(data))
if data=="quit()" then
print("got quit")
uart.on("data")
elseif data=="scan()" then
print("Scanning")
UARTstatus = "scanning"
wifi.setmode(wifi.STATION) wifi.sta.getap(function(t) if t then print("\n\nVisible Access Points:\n") for k,v in pairs(t) do l = string.format("%-10s",k) print(l.." "..v) end else print("Try again") end end)
elseif data=="join()" then
Join()
elseif data=="strongest()" then
wifi.sta.getap(function(t) strongest(t) end)
elseif data=="resetwifi()" then
node.restart()
elseif data=="config()" then
StartHostAP()
elseif data=="dns()" then
StartDNS()
end
--uart.on("data")
end, 0)
if pcall(function () dofile("config.lc") end) then
if HostAP == "true" then
UARTstatus = "Loading|AccessPoint"
print (ssid.." "..password)
StartHostAP()
ProdWebServer()
else
UARTstatus = "Settings Found|"..ssid
Join()
end
else
UARTstatus = "Loading|AccessConfig"
StartHostAP()
end
tmr.alarm(0,30000,1,function() print("Stopping uART") uart.on("data") tmr.stop(0) end)
tmr.alarm(1,5000,1,function() print("!"..UARTstatus) end)
