By nirajbhatt7
#8295 I have tried to flash 2 firmwares (latest and nodemcu_20150126.bin). Esp8266Flasher will show that the firware was uploaded successfully. When I restart the ESP module and open ESPlorer, I get garbage in the output on both the speeds (9600 and 115200). Also the blue LED on ESP is always on. Any idea? All the help appreciated.
Output:
PORT OPEN 9600
Ÿ’ àÇÀ  XG-Š—‚—†W‚‚‚š‡-—‚—‚—†‚‚š‡-—Š—††‚‚š‡-—‚—‚—‚‚‚š‡--‚—†—‚†‚†’Ç%‚—‚—†‚Ɔš‡-—†—†„†‚š‡%—‚—‚—‚‚Šš‡%—Š—„І‚š‡-‚—†—††‚‚š‡-—†—†—‚†‚š‡-‚—‚—†††‚š‡-—†—І†‚ØÇ%‚—‚—‚—‚†‚Ú‡-‚—†—†—Š‚†š‡-—†—‚—‚†‚š‡-‚—‚—‚‚‚‚š‡-‚—†—‚‚†‚š‡%‚—†—†—†Æ„š‡-—‚—‚—‚†‚؇-—†—†—†††š‡-†—†—†—†‚‚š‡-‚—‚—‚‚‚Šš‡%‚—†•†‚‚‚Ú‡-—†—†W‚ƆšÇ-‚—†—ŠŠ‚‚š‡-‚—‚—‚W‚††Ú‡-—Š—†‚‚Šš‡-—†—††‚‚ÚÇ-—†—†—‚††š‡%‚—†—‚—‚†‚š‡-—‚—†W‚‚Šš‡-‚—‚—†—††‚š‡-‚—†—†—†‚„š‡-—Š—Šu„‚†š‡-—†—†Š‚Šš‡-—†—‚—‚Ä‚š‡-‚—†—‚—†‚†Ú‡-—Š—†‚‚ŠšÇ-‚—†—‚—‚†‚š‡-Š—†—†W†‚‚šÇ-‚—‚—†Š‚†š‡-—‚—І‚†š‡-—†—†—††‚š‡-Š—†—‚—‚†‚š‡-‚—†—†‚‚‚š‡-‚—†—‚†‚†š‡-—†—‚†‚†š‡-‚—Š—Š—‚‚‚š‡-‚—†—‚—‚‚Šš‡-‚—†—†—†‚ŠšÇ%—‚—‚—‚††š‡-—Š—Š—‚†‚š‡-Š—†—‚—‚Ɔš‡-—‚—І‚†’Ç-—Š—†U†‚†š‡%‚—†—†—†‚†š‡-—Š—‚—‚‚‚š‡-—†—†—†
PORT CLOSED
PORT OPEN 115200
†ã& àÇÀ € € € b€$œàrÜÜœ‚œÄ’ àÇÀ € € € b€œŸ’ àÇÀ € € €l`Ä�‚ß‚n€$œàrœߨnnŸ„ bŒ
By nirajbhatt7
#8361 Checked at 74880 and am getting below output.
PORT OPEN 74880
€ € €l`!T,W, R¯¬Y\ºZË  SIj¤T �Åê‚ÂÑ‚’Š‚ªÂ±*Á�Éê‚ÂÁ‚‚‚‚‚‚‚b*Á�Íê‚ÂÁ‚‚‚‚‚‚‚b*á�Ù…‘‘Éõ‚ÂÁ‚‚‚‚‚‚‚b"•Á�õ‚ÂÁ‚‚‚‚‚‚‚j¤d*‹W R¯¬Y\ºZË  SIj¤T �Åê‚ÂÑ‚’Š‚ªÂ±*Á�Éê‚ÂÁ‚‚‚‚‚‚‚b*Á�Íê‚ÂÁ‚‚‚‚‚‚‚b*á�Ù…‘‘Éõ‚ÂÁ‚‚‚‚‚‚‚b"•Á�õ‚ÂÁ‚‚‚‚‚‚‚j¤d*‹W R¯¬Y\ºZË  SIj¤T �Åê‚ÂÑ‚’Š‚ªÂ±*Á�Éê‚ÂÁ‚‚‚‚‚‚‚b*Á�Íê‚ÂÁ‚‚‚‚‚‚‚b*á�Ù…‘‘Éõ‚ÂÁ‚‚‚‚‚‚‚b"•Á�õ‚ÂÁ‚‚‚‚‚‚‚j¤d*‹W R¯¬Y\ºZË  SIj¤T �Åê‚ÂÑ‚’Š‚ªÂ±*Á�Éê‚ÂÁ‚‚‚‚‚‚‚b*Á�Íê‚ÂÁ‚‚‚‚‚‚‚b*á�Ù…‘‘Éõ‚ÂÁ‚‚‚‚‚‚‚b"•Á�õ‚ÂÁ‚‚‚‚‚‚‚j¤d*‹W R¯¬Y\ºZË  SIj¤T �Åê‚ÂÑ‚’Š‚ªÂ±*Á�Éê‚x4021058c, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Fatal exception (0):
epc1=0x4021058c, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
By alonewolfx2
#8367 Yo need full Erase chip. And check your power supply.
nirajbhatt7 wrote:Checked at 74880 and am getting below output.
PORT OPEN 74880
By nirajbhatt7
#8378 Thanks for the reply
I am using AM1117 power source board and measured the output with multiplier and power is 3.3 V.
Do you mean doing INTERNAL://BLANK at 0x00000 in ESP8266Flasher.exe
And then I am assuming I have to upload the firmware again.
I have done the above now but the same result.
