Greetings!
Greetings!
Explore... Chat... Share...
static int file_freespace (lua_State *L)
lua_pushinteger(L, fs.block_count * fs.cfg.phys_erase_block - fs.stats_p_allocated * fs.cfg.log_page_size);
return 1;
static int file_totalspace (lua_State *L)
lua_pushinteger(L, fs.block_count * fs.cfg.phys_erase_block);
return 1;
file.c:48:22: error: 'fs' undeclared (first use in this function)It takes about 20-25 seconds for home assistant c[…]
