By qwerty156
#10167 For some reason, during up load, the ESP does not send back >>> arrows and hence the file is no uploaded correctly to the ESP8266. (You cant run the file and the modules forgets the file when you power cycle). This was working yesterday before i reflashed the firmware (It was running the latest firmware). After that I have reflashed many times and even tried an older firmware but the problem persists. Is there a solution?
